Question about DCS WO-230 Electric Double Oven
DCS Built in Double Oven
I am getting a continuous beeping sound and an error code of F-7 on the Display panel. I had this problem once before and my manual told me how to solve it. I cannot locate my manual. Can you help.
  • sallymkirn Sep 24, 2008
    In the manual I had there was a troubleshooting section which told me how to correct this problem. The manual on line did not address that. Please help.
  • 2,071 Answers
    President:
  • 1,952 Answers
Posted on Sep 24, 2008
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Sep 25, 2008
    I have a procedure that is supposed to indicate if the control (circuit
    board) is bad, or the key panel is bad. Instructions to make this
    determination state
    1.Push CLEAR/OFF pad
    2.Disconnect ribbon cable from control and wait at least 32 seconds to see if Code recurs.
    *If code recurs, problem is in the control. Replace control
    *If code does not recur problem is with the Key Panel
    When the F7 code cannot be cleared, the only function
    that works is the clock display - no keypad functionality - so you
    cannot turn on the oven. I have fixed this problem at least temporarily
    by turning off the breaker and removing the keypad and cleaning the
    ribbon cable contacts, put it back together, switch on the breaker and
    it works
    tech sheet gives instructions on how to read error
    codes stored in eeprom memory, that is, push timer, clock, and '9'
    together. When displayed push '8' and '6' to clear (hold them until it
    clears).
    always turn off the circuit breaker first.
    Open the oven door (if you have a double oven, it should be the upper
    one) and remove three screws (on some models just two on corners) from
    the bottom of the control panel. If the control panel on your oven is
    made of stainless steel, then you have to pull the oven out of the
    cabinet for about 2′ to 3′ to get better access. Pull the control panel
    forward and up to remove the tabs on the top of the frame, out of the
    holes in the end caps. Pull the control panel out and turn it about 90°
    toward yourself (the face of the control panel down). Unplug the
    control panel ribbon from the ERC. Remove four screws holding the ERC
    to the control panel. On some models you also have to remove the screw
    which attaches the ground wire to the control panel. Let the ERC hang
    on its wires, remove the old control panel and replace it with the new
    one. On some models before you do it, you have to remove the end caps
    and the bottom shield from the old control panel and install them on
    the new one. Do not forget to plug the new control panel ribbon into
    the ERS slot. Attach the new control panel to the oven and turn the
    circuit breaker on.
    circuit breaker on.
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
Built in double oven GE profile
F7 code is 'shorted matrix or start key' could be due to a problem with the key panel or control.
Aug 05, 2008 | GE Profile JTP56 Electric Double Oven
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
F1 error code and constant beeping and oven shuts off.
Hi gwhiz03,
If you are having error code F1 with your Jenn-Air double wall oven this is because you have a defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope this helps.
Thank you for using FixYa.
Feb 10, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
I have an in the maytag gas oven that keeps beep and show f-1 when its shut off
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC.
6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound).
7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
Nov 02, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
NEED HELP ON DCS WO-230 DOUBLE OVEN
there are 2 screws at the top outside and 2 or 3 on the bottom of the display panel. remove those and the panel should lift off the mount. remove the ribbon cable and 4 screws for the display and replace.
Oct 05, 2008 | DCS WO-230 Electric Double Oven
DCS wall oven F7 ERROR
I TRIED SOLUTION FROM SYMAR DATED MAR 14, 08 IT WORKED FOR NOW. I HOPE IT WILL CONTINUE WORK UNTIL SERVICING...COME MORNING.
Feb 09, 2008 | DCS WO-130 Stainless Steel Electric Single...
DCS WO-230 Electric Double Oven Logo
494 people viewed this question
Top DCS Ovens Experts
ashburton
Joyce Nokleby
NOEL
NOEL
Are you a DCS Oven Expert? Answer questions, earn points and help others
