Question about Whirlpool Washing Machines
Whirlpool front loader error code f-h ? front loader will not spin
  • 943 Answers
Hi thanks for your question. i would check the pump remove the front panel 2 screws on the front panel at bottom remove you will see a big plastic nut in middle un screw but you will get water put a bucket under this nut pull out and clean . this will solve your problem thanks the appliance doc
Posted on Sep 24, 2008
SOURCE:
SOURCE: whirlpool front loader door locked
My followup work-around: I unplugged the machine and drained the water out of the machine. Apparently there is a "lockout" safety feature that refuses to open the door when there is a certain amount of water in the machine. After draining the majority of the water out, I then cleaned the filter (and more water came out- have the bucket and towels ready!). The ultimate problem was that the pump was shot. While reseaching my own records, I discovered that I had purchased an extended warranty for the first and only time because LG was new to making washers. The pump was replaced at no cost within 24 hours.
Posted on Mar 06, 2008
Slinteriors
  • 8617 Answers
SOURCE: Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Posted on Mar 27, 2008
  • 1294 Answers
SOURCE: i have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Posted on Apr 08, 2009
  • 3230 Answers
SOURCE: error code F01 on my
Hi, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU. thanks
Posted on Jun 06, 2009
taran_2005
  • 10515 Answers
SOURCE: LG washerwon't spin
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG was no help on the phone and I the only people that could service it were 45min away from were I live. I took the advice of a posting on this website that it could be a part called the sensor assembly and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next unclip the two sets of wires on the bottom of the circle you are looking at (the set of wires to the right are connected to the sensor assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 03, 2009
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is a whirlpool front loader. It keeps
F/02 Long Drain
  • If the above does not correct the problem, replace the pump.
Jan 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
F06 error with a ghw9150pw4 model whirlpool front loader washer
HI There
Here what you need on error codes.
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Hope this helps let me know. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirl pool duet
Lets run a diagnostic test selecting drain/spin, on spin speed select no spin then press prewash quickly twice, watch for F error codes and write them down, press prewash again to advance past error code seen. Then post back because there are several issues here that can cause this, motor sensor errors, serial communication errors, pump and drain siphon issues.
Sep 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Washing Machines Logo
128 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
