Question about Sharp Microwave Ovens
Display LED's are mostly burned out. and the interior light went out. Sharp Mod.# R-508AK
  • Sharp Master
  • 9,098 Answers
You have to remove the outside cover to get to the light bulb. Once you have the cover off, you'll see the bulb socket to the right of the oven.
Replacements are readily available at grocery stores, places like Wal-Mart or Lowes, and hardware stores.
Concerning the display and controller, we regularly repair these for customers nationwide with our guaranteed $39.95 service in about a week.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 25, 2008
I have a 12yo Sharp r-430cs microwave. The LED is not displaying all the "lights" in the numbers/alpha readouts. It is missing a lot more of the readout than it is showing. Everything else is working
Go to Sharp's website and check availability of the clock/timer readout board. Being that old you may not be successful, but it;s worth a try.
Oct 21, 2014 | Sharp Microwave Ovens
My Sharp R1505 Microwave's LED display is malfunctioning, with only minimal lighting of digital/number segments. Do I need to replace the entire control board with a new LED attached or can I just replace...
You can order a new control unit (part number CPWBFB075MRU0 which comes with a display) from Encompass here.
Or you can get yours repaired for $39.95. Details here.
Feb 10, 2011 | Sharp R-1505 Microwave Oven
Control Display is burning out, many of the LED segments are blank.
Replace the display. It is available as a unit from a Sharp Service Dealer.
Jan 05, 2011 | Sharp R-1610 Microwave Oven
Sharp carousel microwave model # 508ak has power but does not heat food when you press the start button. thanks in advance!
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
thanks.
Jul 11, 2009 | Sharp R-510HW Microwave Oven
Sharp carousel r-508ak - does not heat up the food
You probably have a defective magnetron or blown fuse supply power to magnetron.
May 12, 2009 | Microwave Ovens
Sharp quartz chef combination microwave R-7E53 blows fuse and emits burning smell - display, light, turntable operate but does not heat. Is it worth repairing?
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
Here is a helpful link you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
Info on ordering Sharp UK parts / spares is here.
The best place to order Sharp parts in the US is Tritronics.
Aug 11, 2008 | Microwave Ovens
SHARP R-316F
easy to fix you need to cut the tracks to the led lights then solder 2 wires to the leds next use a 1k resistor on one of the wires then conect it straight to the power surply just after the bridge rectifier noteing+ and -
Mar 06, 2008 | Sharp R-202EW Microwave Oven
Most of the LED display is inop
Give me the complete model # from the sticker inside the microwave so I can look into this for you.
Nov 15, 2007 | Jenn-Air M439 Microwave Oven
Display doesn't work
Give me the entire model # from the sticker on the MW and I will see if I can help. Or go to http://www3.sears.com/ or http://www.appliancepartspros.com/
Nov 06, 2007 | Microwave Ovens
Microwave Ovens Logo
76 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
