Question about Kitchen Appliances - Others
Manuel for Hydro-Quad water processor
I hope you guys are expert for this. Someone gave me household Commercial Grade Water softener Hydro-Quad model HQ948FE, but I need manual how to use it, and it doesn't have power supply. That’s why I want to know what kind of PW it running?
Thanks --Patrick
  • 1 more comment
  • Anonymous Oct 27, 2008
    I have the water softener but I have no idea what to do with it.
  • rdkjs10 Mar 25, 2009
    Bought a home with the 948fe unit. Water in line not connected. How can I find out if this is still a useable unit?
  • Anonymous Mar 15, 2014
    repairman said I need 5600 rebuild kit He ordered it 2-21-14. He says it is on order but not available. I have paid $241.00 upfront
Bought a home with Hydro Quad Water processor model HQ1554 FE 1.0. House came with no manual. How can i find the manual?
Posted on Aug 12, 2009
  • erleross Sep 07, 2010
    Great question, but where's the answer? I also want to find a manual.
I have a hydro quad comm proessor. model h200573 - hq1054fe10. i dont have the manual. what do i do to work it
Posted on Sep 22, 2010
I have the ame problem.. Did you find the manual . Please let em know at shriprashad@yahoo.com
Posted on Jan 16, 2010
No Hot Water
Hard water contains a lot of minerals and depending on how hard the water is also depends on how often you must replace the filters. A much better alternative is to have a water softener installed before your hot water heater and any other sorce of domestic water supplying your home. I have one and it works great. Just be advised that you will need to replace the salt crystals every couple of months depending on the time intervals you set the timer to. If you find that the water still remains soft after two months and your filters are not to badly clogged then you may try adding salt every three or four months and see if that solves your problem. You also have to remember that your also using the water for drinking cooking and bathing so softening your water supply is very important especially if you or anyone in your household ever had any kidney stones or kidney problems.
Good luck,
Marty
May 08, 2014 | Navien CH-240-ASME-LP, Combi Condensing...
Water Softener full of water, not draining, or using salt
How old is the system ? Where does the system drain to ? If this is the softener you have (seems awful large for a household) it is probably the injector/nozzle assembly. I have attached a manual to help you. A restriction in the drain line could also be the problem. Fleck 2850s
Mar 20, 2014 | Fleck 165,000 Grain Series 2850 Commercial...
My daughter gave me her portable air con, can't find the manual and was wondering roughly how much water to put in it. Hope someone can help me with this. Thank you.
Mam, you don't put any water in it. This A/C Unit has a dehumidifier in it, that takes humidity/water out of the household air, which helps make the room cooler.
Feb 04, 2011 | Maytag Portable Air Conditioner M6P09S2A
Where do you put the filtration system if you want to eliminate all sediment from your hot water tank. Doe's it go before or after the softener and into the hot water tank?
There are two water lines connected to water heater.
One is marked Hot and the other Cold.
The shut off valve is on the Cold line.
To eliminate sand and dirt from entering your water heater, the 'sediment' filter should be installed on Cold line.
Sand and dirt are sometimes called sediment, but this type of sediment is not the same as calcium carbonate sediment that accumulates inside a tank that receives hard water.
When you have hard water, then water heater makes calcium carbonate 'sediment' deposits that accumulate in bottom of tank. A 'sediment' filter will not prevent this problem.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
If you have hard water, to prevent calcium carbonate from forming inside tank, you need a water softener.
Water softener will prevent calcium carbonate sediment forming inside tank.
However water softener will shorten life of water heater anode rod.
http://waterheatertimer.org/Replace-anode-rod.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater.
Jan 04, 2011 | General Electric GE SmartWater Household...
Why does my Tefal Pro express stain my ironing with brown marks and scale, I fill the tank with softened household water, but I still get a sudden gush of brown scale water. We live in a very hard water...
Its a real pain, but use only distilled water.
Fill your iron with white vinegar and let it steam until empty.. face down on a towel on lowest steam setting.
Nov 26, 2009 | Tefal Irons
Stale smell on crockery after wash
Most commonly, this relates to sulfides or other impurities in the water itself, but may also be caused by a buildup of food soil within the washer. Smell a clean glass of water. Does it smell stale also? If no, clean the screens and wash water sump/tank within the machine.
You can also clean the inside of the machine by using a commercial grade dish machine detergent and increasing water temp if possible.
If the water smells stale, consult a local water expert for guidance in resolving
Aug 19, 2008 | Dishwashers
Salt for DDW1805 Danby
I use ordinary household water softener salt crystals, not pellets, or table salt. The table salt often is not as refined as softener crystals, and can damage the dishwasher's softener in time. Also, the water softener salt comes in a large bag (around 25-50 lbs) for about $6 US.
Jul 12, 2008 | Danby DDW1805W Designer Series...
Kitchen Appliances - Others Logo
5,502 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
