Question about One For All URC4110 Remote Control
ONE FOR ALL UCR4220
THE REMOTE THAT YOU SHOW FOR ONE FOR ALL URC4110 IS VERY SIMILAR TO WHAT I HAVE BUT IT HAS 2 LARGE OVAL CHANNEL AND VOLUME BUTTONS. COULD YOU PLEASE LET ME KNOW IF YOU HAVE THAT MODULE?
WERE IS THE CH+ BUTTON ON THE UNIVERSAL REMOTE
Likely channel up or advance to the next higher channel button
Nov 08, 2014 | Televison & Video
I have bought an Antsig universal remote control for my Sony DVD CMT-GP8D but the 4 diget code is not in the operation book. Please help
Have you tried the manual option? Turn on your DVD player. Press "TV" or maybe a different button for DVD players, then a red light on your remote blinks once. Then hold both the "up" volume and "up" channel button down until your red light is permanently on. Then whilst holding your remote control 1mm away from your DVD player signal light (usually red too), hold down the "power" button until your dvd player switches off. Then switch it on again and try other buttons. However, I've only tried this on an LG TV, but took me 2 days until I really put the remote in front of that signal light. Took about 1 minute or more while holding down the "power" button. Hope it works =)
Jan 30, 2011 | One For All URC4110 Remote Control
Im trying to program a remote the tv is a zenith
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
1.Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
then release SET.
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
6.You are set
thanx
Jul 24, 2010 | One For All URC4110 Remote Control
Urc4110
Polaroid 0765
1. Turn on a your TV
2. On the remote control,press a device key (i.e. TV) once ). Press and hold SET until the LED blinks twice, then release SET.
3. Enter the first four-digit code for your component (0765). If performed correctly, the LED will blink twice.
NOTE: If the LED did not blink twice, then repeat steps 2 through 3 and try entering the same code again.
For more advice and troubleshooting, download the URC4110 User Manual with all codes from here:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc4110-manual.zip&area=other
Jul 10, 2009 | One For All URC4110 Remote Control
CHANNEL CHANGER ON MY URC3220
I followed the tech's suggestion and bought another remote. Thank you.
May 27, 2008 | One For All URC4110 Remote Control
URC -3220 TV BROCKSONIK iHAVE THIS CODE 1449
WE NEED A CODE FOR A ONE FOR ALL REMOTE URC-3220
Jan 24, 2008 | One For All URC4110 Remote Control
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
One For All URC4110 Remote Control Logo
27 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
