Question about Zoltrix Zling U2 MP3 Player
Jngbnrjf jfhwoujn jfnjfkyn hunv hhwn vjuj aa ss dd ff jj kk ll
How to Make the Matrix Raining Codes by Using Only Notepad?
thats easy..
open notepad then copy and paste the following text
@echo off
color 0a
cls
:a
set /a a=%random%
if %a% geq 16384 set /a aa=1
if %a% lss 16384 set /a aa=0
set /a b=%random%
if %b% geq 16384 set /a bb=1
if %b% lss 16384 set /a bb=0
set /a c=%random%
if %c% geq 16384 set /a cc=1
if %c% lss 16384 set /a cc=0
set /a d=%random%
if %d% geq 16384 set /a dd=1
if %d% lss 16384 set /a dd=0
set /a e=%random%
if %e% geq 16384 set /a ee=1
if %e% lss 16384 set /a ee=0
set /a f=%random%
if %f% geq 16384 set /a ff=1
if %f% lss 16384 set /a ff=0
set /a g=%random%
if %g% geq 16384 set /a gg=1
if %g% lss 16384 set /a gg=0
set /a h=%random%
if %h% geq 16384 set /a hh=1
if %h% lss 16384 set /a hh=0
set /a i=%random%
if %i% geq 16384 set /a ii=1
if %i% lss 16384 set /a ii=0
set /a j=%random%
if %j% geq 16384 set /a jj=1
if %j% lss 16384 set /a jj=0
set /a k=%random%
if %k% geq 16384 set /a kk=1
if %k% lss 16384 set /a kk=0
set /a l=%random%
if %l% geq 16384 set /a ll=1
if %l% lss 16384 set /a ll=0
set /a m=%random%
if %m% geq 16384 set /a mm=1
if %m% lss 16384 set /a mm=0
set /a n=%random%
if %n% geq 16384 set /a nn=1
if %n% lss 16384 set /a nn=0
set /a o=%random%
if %o% geq 16384 set /a oo=1
if %o% lss 16384 set /a oo=0
set /a p=%random%
if %p% geq 16384 set /a pp=1
if %p% lss 16384 set /a pp=0
set /a q=%random%
if %q% geq 16384 set /a qq=1
if %q% lss 16384 set /a qq=0
set /a r=%random%
if %r% geq 16384 set /a rr=1
if %r% lss 16384 set /a rr=0
set /a s=%random%
if %s% geq 16384 set /a ss=1
if %s% lss 16384 set /a ss=0
set /a t=%random%
if %t% geq 16384 set /a tt=1
if %t% lss 16384 set /a tt=0
set /a u=%random%
if %u% geq 16384 set /a uu=1
if %u% lss 16384 set /a uu=0
set /a v=%random%
if %v% geq 16384 set /a vv=1
if %v% lss 16384 set /a vv=0
set /a w=%random%
if %w% geq 16384 set /a ww=1
if %w% lss 16384 set /a ww=0
set /a x=%random%
if %x% geq 16384 set /a xx=1
if %x% lss 16384 set /a xx=0
set /a y=%random%
if %y% geq 16384 set /a yy=1
if %y% lss 16384 set /a yy=0
set /a z=%random%
if %z% geq 16384 set /a zz=1
if %z% lss 16384 set /a zz=0
echo %aa% %bb% %cc% %dd% %ee% %ff% %gg% %hh% %ii% %jj% %kk% %ll% %mm% %nn% %oo% %pp% %qq% %rr% %ss% %tt% %uu% %vv% %ww% %xx% %yy% %zz%
goto a
Dont copy this line or anything below it.
once the text is pasted into notepad. click file then Save As...
where is says Save as type: click the drop down and select All Files
the save Type the File name: as Matrix.bat
or you could just google how to make a Matrix bat file.. LOL
Oct 20, 2016 | Microsoft Computers & Internet
How to reduce the repeat speed of keyboard PA3959U-1ETB
YY EE SS JJ UU SS TT TT AA PP how many you want
hope this helps
Jun 30, 2012 | Toshiba PA3959U-1ETB New
1. I have a ASA 5505 and I want to block downloading of several file extensions like .exe, .msi etc on several machines but not all of them. I am running DHCP from the ASA 2. On the machines where...
HI,
You shall do the same with MPF. Create a regex filter to identify the types of files you would like to block,
e.g. 1
5 regex archive-type1 ".*\.([Zz][Ii][Pp]'[Tt][Aa][Rr]'[Tt][Gg][Zz]) HTTP/1.[01]"
regex archive-type2 ".*\.([Tt][Aa][Rr].([Gg][Zz]'[Bb][Zz]2)'7[Zz]) HTTP/1.[01]"
regex doc-type1 ".*\.([Dd][Oo][Cc]'[Xx][Ll][Ss]'([Pp]){2}[Tt]) HTTP/1.[01]"
regex doc-type2 ".*\.([Pp][Dd][Ff]'[Oo][Dd][Tt]) HTTP/1.[01]"
regex exe-type1 ".*\.([Ee][Xx][Ee]'[Vv][Bb][Ss]'[Vv][Bb][Aa]) HTTP/1.[01]"
Create regex for Content-Type Application/*
2 regex application-header "application/*"
regex content-type "Content-Type"
Classify regex that matches the extension types
class-map type regex match-any ext-types
match regex doc-type1
match regex doc-type2
match regex archive-type2
match regex archive-type1
match regex exe-type1
Capture the http response that contains content-type and application/* header
class-map type inspect http match-all http-header-response
match response header regex content-type regex application-header
Capture http request packet that matches the class ext-types
2 class-map type inspect http match-all http-request
match request uri regex class ext-types
HTTP is the interesting traffic
4 access-list http-traffic extended permit tcp any any eq www
access-list http-traffic extended permit tcp any any eq 8080
class-map http-traffic-class
match access-list http-traffi
Create policy to prevent download attempt via http request
6
7 policy-map type inspect http block-http-download
parameters
protocol-violation action drop-connection log
class http-header-response
drop-connection log
class http-request
reset log
Apply policy on the interesting traffic
3 policy-map inside-http
class http-traffic-class
inspect http block-http-download Apply the policy onto interface to take effect
1 service-policy inside-http interface inside
Hope this would help.
Aug 31, 2011 | Cisco ASA 5505 Firewall
If i want to find coordinates how to put degree and " and ' cant find how to separate these and insert proper coordinated
To convert decimal degrees to minutes and Seconds (i.e DD° MM' SS")
i.e: you have 27.2926 N
You know the DD will be 27
This leaves 0.2926 to express as MM'SS".
.2926 x 60 = 17.556 = MM' = 17'.
This leaves 0.556 minutes to convert to seconds (SS")
0.556 x 60 = 33.36= SS" = 33.36
Therefore: 27.2926° N = 29° 17' 33.36" N
Now to go the other way (and to give some proof to the validity of the above...)
29° 17' 33.36" N
DD°+(MM'/60)+(SS"/3600)= 29°+(17'/60)+(33.36"/3600) =27.2926
Nov 10, 2009 | Nokia N500 Auto Navigation
My keyboard double types each letter, i.e. "dd", "kk", when I kit the key once. What can I do to correct?
Hey,
Goto Start-> Settings-> Controlpanel-> Key board settings
In the keyboard properties, drag the repeat delay slider towards long. Now test the keyboard and try again until the problem in fixed.
Thank you
Apr 11, 2009 | Microsoft K5100141 Keyboard
I cant do puzzel 97 in the tower please help xxx
Here is your solution. Thanks and please don't forget to give this solution a rating of fixya.
097 Princess in a Box 1
Purple block = P
Blue block = B
Green block = G
Red Block = R
(l)eft (r)ight (u)p (d)own
G[r],G[r],P[r],G[dd],G[ld],B[rr],R[u],G[ll],G[ul],G[lu],G[ll],P[d],G[l],
G[u],P[r],G[dd],G[rd],B[d],G[ll],G[ul],P[uu],G[rd],G[rr],B[d],G[dr],R[r],
G[uu],G[lu],B[ll],G[dl],G[dd],R[r],G[ru],B[u],B[u],G[ll],G[dl],G[ld],
R[d],G[rr],G[rr],B[u],B[u],G[ul],G[lu],G[ll],R[d],G[dl],P[l],G[uu],G[uu],
R[r],G[dd],G[dd],P[l],G[lu],R[urr] = 57 moves
Mar 01, 2009 | Nintendo Professor Layton & the Curious...
Im stuck on puzzle 132 can somone help
132 Princess in a Box 2
Blue block = B
Green block = G
Red block = R
Purple block = P
G[dd],P[r],P[uu],G[ru],B[rr],R[d],G[ll],G[ul],G[lu],B[u],G[ll],
G[dl],P[dd],P[r],G[ru],B[u],G[ur],R[r],G[dd],G[ld],B[ll],G[dl],
P[l],P[uu],G[r],G[r],R[r],G[rd],B[d],G[ll],G[dl],P[l],P[l],G[uu],
G[uu],R[r],P[dd],P[l],G[lu],R[urr] = 40 moves
Thanks and please take a moment to rate as fixya.
Feb 22, 2009 | Nintendo Professor Layton & the Curious...
ASUS m2n32 won't allow me to go into setup; shuts down...
Try to reset your BIOS by removing the button cell located at your motherboard and put it back. Check the SATA connector of your hard drive and make sure it fits right. Boot the machine and set-up to "boot from CR-ROM". And install new WINDOWS XP.
Jan 04, 2009 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
How to calculate total downtime of a perticulor ticket. for ex: if a perticulor ticket being opened three days before and the end time would be 4th or 5th day, so the ticket details would be containing,...
cell 1 = logged in date <mm/dd/yy>
cell 2 = logged in time <hh:mm:ss>
cell 3 = resolved date <mm/dd/yy>
cell 4 = resolved time <hh:mm:ss>
cell 5 = cell 4 + cell 3 - cell 2 - cell 1 <general format>
cell 6 = day(cell 5) <general format>
cell 7 = hour(cell 5)&":"&minute(cell 5)&":"&second(cell 5) <general format>
Nov 18, 2008 | Computers & Internet
IE DATA 702 fdd
Hello
I beleave it uses a HD/DD type of disk
Abbr.
Floppy Disk Type
Capacity
Info
SS/SD or 1S/1D
Single Sided, Single Density
100 K
First generation. Capacity varies
SS/DD or 1S/2D
5-1/4 inch Single Sided, Double Density
180 K
DD/DD or 2D/2D
5-1/4 inch Double Sided, Double Density
360 K
Most common type in the early 1980's
DD/HD or 2D/HD
5-1/4 inch Double Sided, High Density
1.2 Mb
DD
3.5 inch Micro Floppy, Double Density
720 K
Hard plastic case
HD
3.5 inch Micro Floppy, High Density
1.44 Mb or
2.88 Mb
Hard plastic case
May 05, 2008 | Ye Data YD-702D (850416000107) Internal...
Zoltrix Zling U2 MP3 Player Logo
35 people viewed this question
Top Zoltrix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Zoltrix Audio Player and Recorder Expert? Answer questions, earn points and help others
