New Hampton Bay Model 640-657 Classic Collection Burgess 54" Celing Fan with Remote. I have had installed by electrician ,also re checked by different electrician. Both have charged me and told me it is wired correctly. Comes on some time by itsself and then light will not go out. I have replaced the battery 3 times with no help. I have wired into a wall switch . prior to the Fan. Could use some help. Is there a kit I can wire without the Remote. Fan is less than 3 weeks old. Getty costly to keep having electricians come out.
5 Suggested Answers
  • 143 Answers
SOURCE: We recently bought a hampton
I think this is not an air conditioner. Try posting this under "fans".
Posted on Jul 25, 2008
rickzilla
  • 706 Answers
SOURCE: Hampton Bay 52" Classic Collection Almeida 52101916
Electricians can be so much fun can't they ? LOL I would ask the electrician to bypass the remote to check the fan operation first. You need to know if your problem is the remote or the fan itself.. A simple wiring change in the junction box can be done to determine which issue to focus on.. Hope this helps..
Posted on Sep 03, 2008
  • 10865 Answers
SOURCE: I'm replacing an existing ceiling
Hi. The fan has its own built in Variable speed setup. In the case that the red wire belongs to the variable device, wire the Red to Blue(light), and Black to Black Whites to white. Green to Ground. bare wires to ground. Joe
Posted on Sep 26, 2010
  • 3069 Answers
SOURCE: The Hampton Bay has a
The green wire is ground, the white is neutral, and the black it hot. I really do not understand the question, as the pull chain for the light switch is black and usually there is like blue wire for the lighting kit( which is marked light) as the light sits under the fan housing. The power is wired up top black to black , white to white, and green to ground. Unless you are using two switches one for the light and the other for the fan. I hope this helped Tim
Posted on Oct 24, 2010
  • 414 Answers
SOURCE: how do I wire a
The blue (or black) wire from the light kit is connected to the black wire inside the fan cover.
The white to the white. Make sure to secure power to the circuit before attempting work.
Hope this helps.
l
Posted on Feb 21, 2011
Purchased Hampton Bay Ceiling Fan, Midili White 44", Model #71606 with remote from Home Depot. I have 2 switches wired to the lattter with 1 for the fan and the other for the light. Can I install...
Yes, you could, but you want have any way to control the fan speed. Unless, you install a rheostat that is rated for electric motors. A light dimming rheostat is not heavy duty enough, to handle the fan motor without over heating.
Hope this helps you and thanks for choosing FixYa.
Aug 25, 2011 | Hampton Bay Heating & Cooling
I have a hampton bay remote that just stopped working. I have installed new batteries, have checked the code with another remote so I know the problem isn't the fan. The light on the remote does not...
If the light on the remote is not lighting when you push a button, check the batteries to make sure they are in the proper position. If one is turned the wrong way, the hand held will not work. You may also want to check the replacement batteries to make sure they are fully charged. If all this fails to solve the problem, you will need replace the hand held remote. Since Hampton Bay Fans are a house brand for Home Depot, they stock and sell replacement hand held remote controls.
Hope this helped you. Please let me know. Thanks.
Jul 13, 2011 | Hampton Bay Heating & Cooling
Hi I have a hampton bay st regis 60 inch fan I need the remote it just goes in revverse. When I brought the house there was no remote. It is hook to the light fixture switch. It only goes in reverse is...
Hi, Betty. Hampton Bay Ceiling fans are a house brand for Home Depot. They do sell replacement hand-held remotes, that can be programmed to match your fan. But, before you rush off to buy a new one, change the batteries in the remote first. There's a batteries in the handl held remote and some in the receiver, inside the fans cowling. Low batteries can cause what is happening with your fan.
Jul 12, 2011 | Hampton Bay Heating & Cooling
I have a Hampton Bay Cieling fan, model # FAN- DH L3H2003, and the remote control does not work. How can I get a replacement?
before you buy a new hand-held remote ... have you changed ALL the batteries. There's a set in the hand-held remote and batteries in the receiver, which is behind the fan's cowling. If you haven't changed them all, I'd do that before investing in a new remote control.
if you find, after changing all the batteries, you do need a new remote control, here is a link to one for all Hampton Bay Ceiling Fans.
http://www.homedepot.com/h_d1/N-5yc1v/R-100071965/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Jun 01, 2011 | Hampton Bay Heating & Cooling
We just bought a house with a beautifiul Hampton Bay ceiling fan, however the remote is missing. Consequently, we are unable to use the fan. Is there any way to determine if the fan is operational?
Try Home Depot. They sell Hampton Bay fans. They should have replacement remotes.
Here is one that Amazon sells. If you order oline, check to see if your model number is
what the remote will control. Also return policy of the seller if it doesnt work. May be easier
to go to Home Depot with a picture of the fan, or model number if you can locate it. Remember
that you will still have to figure out what settings to set the switches to that control the channel
the remote works on. It's do-able.
http://www.amazon.com/Hampton-Bay-Portable-Ceiling-Control/dp/B002L9SHJ4
Mar 19, 2011 | Heating & Cooling
Remote operation of ceiling fan NOT working.
Try to check the remote control by using camera or cell camera, just use it as your eyes to see if the remote control emits signal. Just point your remote control to the camera and "on" then check if the remote control emits light, if no emitted lights means defective remote but if emit lights then the receiver is defective . Try also to locate if there are any reset or rst button on the remote control and press it then test.
Dec 31, 2008 | Hampton Bay Heating & Cooling
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
