How do i print a borderless page using a Canon iR C4080 PS3
  • 26 Answers
SOURCE: printing from iphoto - photos are not 4x6 and not borderless
wat pc do u have? are u using mac? if ur using microsoft try these:
go to ur printer and faxes - right click on ur hp printer icon - select preferences - select printer shortcut tab - select the appropriate size - the click ok. that should solve ur problem
Posted on Jun 11, 2008
SOURCE: HP C6180 won't print borderless photos
Also had ongoing problem of paper jams printing PDF files, but not when printing any other files. Solved both problems by uninstalling and reinstalling printer driver.
Posted on Feb 05, 2009
latcarf
SOURCE: MP600 with Mac OS X - no borderless printing option?
I had the same question. I found the answer at Canon's site but I can't link directly to the page so here's how I found the solution...
1. Go to the Canon Support site. 2. In the "Please enter your question field" type: How do I Print edge to edge? 3. Hit the "Search" button. 4. Click the #1 (top) search result "How do I Print edge to edge?" 5. Click the #1 (top) solution: "Use Borderless Printing (Mac OS X) MP600 6. Follow the directions.
It seems the main thing you need to do is go to the "Page Setup" dialog. Then make sure you've chosen the MP600 in the "Format for:" popup menu. Finally, in the "Paper Size:" popup, select "A4" then "A4 (borderless). It's a hierarchical menu.
FWIW I still haven't gotten a "perfect" borderless print. Seems you gotta get the paper in there exactly straight...
Posted on Mar 10, 2009
SOURCE: settings for printing a borderless 8x10 on a canon i9900
Downloaded following program for Vista and was able to print borderless pictures on Canoni9900
Easy-PhotoPrint EX Ver.2.0.3 (Windows Vista/Vista64/XP/2000)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9870#DownloadDetailAct
Posted on May 25, 2009
  • 39 Answers
SOURCE: can't print entire pdf documents only first page.
Try this
For Adobe Acrobat Professional 9:
  1. Choose File > Print.
  2. Click on Advanced.
  3. Choose Postcript Options.
  4. Under Font and Resource Policy, select "Send for Each Page".
  5. If "Print as Graphic" is checked, it must be unchecked, as well as "Send As Group" if it does not uncheck itself when you select "Send for Each Page"
  6. Save it as a custom configuration.
Posted on Oct 06, 2009
Canon IR C4080 - Is there a way to reset/adjust the alignment for color layering for print jobs? My Cyan, Magenta, and Yellow are all off. Thanks!
Sounds like the copier is needing to have a DC Controller or MMI reset. Before doing this make sure you have printed out the current setting in P Print, Addresses ( E-mail, Faxes, etc. ), and any other items that may be stored in the copier. I can't remember all the items a " CLEAR " will wipe out but it's a good policy to have a current copy of this printed out anyway. Before doing the clear, look to make sure the settings agree with canon print settings located behind the door panel.
Good Luck.
Jun 08, 2011 | Canon imageRUNNER iR C4080 Color Copier
How do I print the configuration report page on the irc4080?
If your looking to do a configuration report of the copiers internal settings you must be in service mode level 1 and under Copier>Function choose Misc-P then P-Print. Now push OK and within 30 seconds the machine will print the internal configuration. You can do this with all newer Canons.
May 27, 2011 | Canon imageRUNNER iR C4080 Color Copier
Colored ink is smearing on the page when I print
Did you change the toner?Developer unit? When did it occured?
FIRST: the copier must be cleaned and vacumed, it may be that toner falls onto transfer section and that causes the problem, you may also have problem with yellow developing unit or drum or transfer cleaning blade.
Pls. rate
May 07, 2010 | Canon imageRUNNER iR C4080 Color Copier
Canon iR C4080 scan to email / file and manual
as a set off drums for this model costs around £900 i@d get a service contract try concept group if your in uk download drivers from www.canon.co.uk go to download page and enter your op sys and language as for scan to mail use your RUI to check smtp settings username and password havent changed
Jul 22, 2009 | Canon Office Equipment & Supplies
Steps for scanning and emailing a document using IR C4080
Scan to a folder and use barcode sheets with PixEdit will do it
Jun 15, 2009 | Canon imageRUNNER iR C4080 Color Copier
Jan 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
88 people viewed this question
jasbo
jasbo
