Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Bypassing automatic shutoff
Hi! How do I bypass the automatic shutoff on my GE Gas Range. I want it to stay on continuously.
  • 2 more comments
  • y2ksmk Sep 24, 2008
    How do i bypass the 12 hour shutoff?
  • y2ksmk Sep 25, 2008
    It's model # JGSP22 or 23. Thanks!
    Not sure what the age is though...
  • y2ksmk Sep 26, 2008
    What are the minute slew pads? Is that the + and - buttons?
  • 750 Answers
Hello y2ksmk Welcome to fixya.
I'm Huuum and happy to assist you,
What is the model number and the age of your range?
Huuum
I'm here AL night.
Posted on Sep 24, 2008
  • 1 more comment
  • Neil Golan
    Neil Golan Sep 25, 2008
    Hello y2ksmk
    huuum here ,
    Below at the end is your answer how to over ride the feature
    let me know!
    Please leave a rating before you leave,us
    thank you
    Range - 12-Hour Automatic Oven Shut-Off
    The 12-hour automatic oven shut-off
    provides peace-of-mind and energy savings if the oven is accidently
    left on. The oven automatically shuts off after 12 hours. The 12 hour
    time was chosen because it allows through the night baking and is not
    too long for the oven to stay on.
    "QS" - "QuickSet"
    Note: The twelve-hour automatic oven shut-off is offered on QS-II and QS-III models.
    As of 1995 some ERC II's (QS-IV's) have the 12 hr shut off.
    12-hour shut off is offered on all SmartSet Control models.
    Note:
    Effective 7/97 all Free standing electric ranges produced 7/97 and
    later with QS-IV and V will now have the 12- hour automatic shut off
    and the override feature.
    Please consult the Owner's Manual for model specific information.
    Download a copy of the Owner's Manual and/or Installation Instructions.
    Override for the Twelve Hour Shut Off.
    Effective 5/98 all Freestanding gas ranges with QS-IV and QS-V will also have the override feature.
    Models include: JGBP90mea, JGBP86, JGBP85, JGBP79AEA/BEA/WEA and JGBP35BEA/WEA/AEA.
    Note: Any free standing gas range with
    QS-IV or V does not have the override feature if manufactured prior to
    5/98.
    • QS-II and QS-III models produced 4/96 and later can "override"
      the twelve hour shut-off. (Both gas and electric)
    • All Smartset Controls have the Override feature.
    • Effective 7/97, Free standing electric ranges produced 7/97 and later
      with QS-IV and V will have the override feature. Models include:
      JBP79WY/BY/AY, JB940WY/AY/BY, JB960WY/AY/BY.
    Note: To turn override on or off press
    the minute slew pads for 4 seconds until the word off or on appears.
    The oven must NOT be operating to do this.
  • Neil Golan
    Neil Golan Sep 26, 2008
    Dear y2ksmk,
    Did the override feature work for you?
    Huuum
    Note:
  • mpd8
    mpd8 Sep 16, 2012
    So if I don't want it to turn off it should say on or off?
Have gas coming out of exhaust
Fuel bypassing float. Float has a hole in it or adjusted to low. Or fuel shutoff solenoid is bad.
Nov 17, 2015 | Garden
50 gallon **** power vent LP with flammable vapor sensor problems can you bypassing
You can't bypass a flammable vapour sensor. it works on resistance not continuity. You can try moving the sensor outside for a while and it may reset itself...meaning that the resistance may fall back within range. You are best to have the sensor replaced by a qualified technician who can also verify that you do not have an underlying issue such as a gas leak which is causing the sensor to trip.
May 10, 2014 | RHEEM 50 Gallon FVR NATGAS Water Heater...
GE JKP28 oven light is always on
It is possible the relay for the light on the control board has welded points. A door switch could be bypassing the control. keeping the light on when the door is closed. Hope this helps.
Feb 10, 2014 | GE JKP28 Electric Double Oven
99 tahoe will only start when bypassed
Automatic or manual transmission ? tumbler sends voltage ??? What tumbler ? Ignition switch ,when it start position sends B+ voltage to the crank fuse in the insturment panel fuse box ,from there it goes transmission range switch,if in park or neutral it then goes through the relay pin 86 at the relay socket base . With the key in start you should see B+ voltage there . If not ,try moving the gear selector to neutral . if you still don't see B+ voltage , find the trans .range switch an check it.
Sep 27, 2017 | 1999 Chevrolet Tahoe
Water from GE Profile Refrig/freezer drips down back inside freezer wall and fills up, bypasses drain and fills up and leaks into floor.
Hi, Is it bypassing the drain or is the drain plugged? The most common is that the drain hole gets iced up and them overflows onto the floor.
Just wanting clarifcation.
Jul 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Engine will not start. Trying pull out an injector to check spray volume. Can't seem to get it loose to pull out. Is there some ''trick' to releasing the injector?
IS YOUR TOGGLE SWITCH TO CUT IT ON AND OFF WORKING PROPERLY, ALL YOUR SHUTOFF SENSORS ( LOW OIL,ETC) BYPASSING CORRECTLY DURING STARTUP BY THE BYPASS BUTTON BEING DEPRESSED.
YOU CAN ALSO TRY SOAKING A RAG WITH GASOLINE AND RINGING IT OUT GOOD. NOW HOLD IT OVER THE "MOTOR" INTAKE-HOLD GOOD AND DONT LET GO- AND SEE IF IT WILL START. IT ACTS LIKE ETHER BUT WONT VAPOR LOCK IT. THIS WILL ALSO HELP GET RID OF AIR IN YOUR INJECTION SYSTEM.
Apr 16, 2009 | Air Tools & Compressors
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 range gas smell
it's the safety valve, it's bypassing the gas. for you to put soup in there you will have to remove the oven burner. and put the soup on the tip of the orifice that's where the burner sits on.
Dec 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Bybass auto shutoff (frigidaire gas range ES340)
Look on page 10 of the use and care manual under "To Set Control for Continuous Bake or 12 Hour Energy Saving" Page 10 in my manual.
Apr 22, 2008 | Frigidaire FEF336BC Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
612 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
