Question about Grilling
BBQ will not heat up to cook meat
I have a Coleman 4000 grill and lately it is not heating up enough to cook the meat. It was working last week and there is plenty of gas...
What is the problem?
  • shoffee May 14, 2009
    my barbeque has been in storage for about two years. its been used a hand full of times prior to the storage and worked great! after removing it from storage it will not get hot enough to cook any of the meat what do i do?
  • Anonymous Mar 22, 2014
    a new cooking grill for laguna 2 gas burner bbq
You had the burners on before you opened the valve on the propane tank.
this causes the safety in the pressure regulator to cut off most of flow, and the highest temp you'll get will be about 200 degrees.
turn off the burners and the tank, then disconnect the tank and let site for a few minutes. reconnect everything, and make sure you open the tank valve before the burner valves.
Posted on Feb 01, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
The gas line. try this, turn on flame and move the tank around, try laying it down giving the hose a stiffer/more rigid connection. the flame s should come out a lot higher.
Posted on Sep 25, 2008
Meat weighs 2llb 20oz how long should i cook it for we like it medium rare ?
The best thing you can do is to buy a BBQ digital thermometer that you place in the meat during cooking. They have a heavy duty wire with a temperature probe on the end. Sear the meat directly over the coals (or hot side of a gas grill), then move the meat to a cool side and then insert the temperature probe and close the grill lid. Cook until it reaches desired temp, for me 125 degrees is perfect. The total cooking time is hard to judge as it depends on your grill cooking temp, but the digital thermometer takes all of the guesswork out of the equation as to when the meat is done.
Apr 06, 2015 | Grilling
Tip
Tip on Grilling
When grilling meats, it is usually best to turn the meat only once. When grilling meat to a medium or greater doneness, use the lid to assist in cooking. This will decrease the cooking time by applying heat to all sides of the meat at once.
on Aug 17, 2010 | Grilling
Food sticks to griddle
You can either use a cooking spray like Pam on the griddle prior to heating it. Or if you're cooking steaks, rub a little olive oil on each side of the steak, before seasoning (kosher Salt & Fresh Ground Pepper) it. For meats, always allow them to come to room temperature before grilling and allow the grill to preheat until is extra hot. The hotter the grill/griddle, the less likely red meats will stick to it.
Hope this helped you and Happy Grilling!! Thanks for choosing FixYa.
Aug 12, 2011 | Coleman Roadtrip Grill LXE 9949-750
The best way to cook on this grill and how do you use the smoker on the grill. I put some meat on this grill and all my meat burn up. also I will like to know how to use the small smoke box on the side.
Hi dale37...
The small smoke box on the left is used to put your charcoal/wood in, this is where your heat and smoke will come from to cook your meat.
You will adjust your heat going to the large side by adjusting your air vent/s.
It is meant to cook the meat slowly as to make it "fall of the bone" tender.
Great for doing pulled pork also....just takes lots of time because your slow cooking the meat.
Do not use charcoal/wood under the big grill side unless you plan to stay with and turn the meat to keep from burning it.
Please take time to rate me
Jul 30, 2011 | Char-Broil Silver Smoker
How can i sear with my weber gas grill?
When you sear meat all you are doing is cooking the outside at high temperature so a caramelized crust forms. To do this on a gas grill turn all of your burners on high, close the top and let the grill get very hot, I usually shoot for around 400 to 450 degrees. When you put the meat on the grill do it fast, directly over the heat source and close the top to keep the heat up. You'll have to experiment but usually about a minute and a half to two minutes per side is all it takes. You want the meat to be thoroughly browned on the outside. Now turn the heat down or off on one side if your grill is set up for that, flip the meat and cook it slowly on the side of the grill that's turned off or over indirect heat to your desired done-ness. This will depend totally on the thickness of your meat, again experiment. Another important step is to let the meat stand for five to ten minutes after taking it off the grill. This keeps all the juices from running out of the meat the first time you cut into it and ending up on your plate.
Jan 17, 2011 | Garden
How to char-broil burgers
You want to know how to char broil hamburgers right? Here is what you do! Start your BBQ 5 to 10 minutes before you put your burgers on (for gas BBQ) and let the metal racks heat up. Keep the top closed to let the heat go through the unit.
If your using a charcoal bbq wait until your coils are white hot and the racks are as hot as you can get them.
Don't buy the hamburger meat that has the smaller amount of fat in it. Get the stuff that has 15 to 20% fat in it. The juice in the fat will help cook the meat and taste better in a burger.
Put your rack on the lowest place as close to your fire/coals as possible.
When the bbq is hot Take your patties and plut them on the rack. If its hot enough you should hear a sizzle sound. DO NOT TURN THE MEAT. Let it sit on the grill and every few minutes take your spatula and press the meat flat on the grill to release more juices and get more attention from the flame or coals. This is what makes the black grill lines on the meat.
You only flip a grilled burger one time after putting it on the bbq. It should cook at least ten minutes or more on one side. If you turn the meat and there are no marks on it then you didn't wait long enough.
Sep 29, 2010 | Computers & Internet
How do you set the airvents for cooking a chicken? How many coals do use?
you need to experiment a bit, good method is to have very hot grill, step meat inside for 5min with vents open - this will from outside skin, then close the vents and lower the temperature to allow meat to cook.
i usually close airvents for any meat as this preserves bit of humidity and meat is soft and tender inside, last two to five minutes i open airvents to allow formation of the skin on the meat.
usually you keep grilling time 1kg/1h you can extend that for game meat up to 1h20min/1kg and you need to reduce it for fish to 30min/1kg
you can actually smoke your meat, chicken or fish in your grill as well. but you did not ask for that :-)
now, how many charcoals, check what is the weight of the meat and about 1/3 to 1/2 of that weight is needed to cook it, in general, per kilogram of meat you need sufficient charcoal for sustaining fire for 1hr, that rule applies to any charcoal or wood cookers, grills or bbq. brand is irrelevant, even from this same brand, you need to experiment a bit to get best results. enjoy!
Jul 26, 2010 | Weber One-Touch Gold 18.5 Grill
Is meat placed in main grill or in attached box
The "offset" box is your firebox. This is where you will put your charcoal. The meat goes in the larger chamber on the grill. This type of cooking is known as indirect cooking where the heat source is not directly under the meat. A grill cooks direct with the heat source coming from charcoal or gas burners located directly under the cook grills. Smoker can really deliver some great tasting food. Be patient and learn the ins and outs of cooking with a smoker. The most important thing is to cook low and slow. try to keep your temps in the cook chamber around 225. I hope this helps.
Jun 29, 2010 | Char-Broil Sierra Offset Smoker
Need help smoking briskett on Char Broil Grill with smoker box
wood chips in the fire box. very low heat. around 200 degree.
maek sure the wood chip is wet and produce smoke. you need to monitor this through out the process.
briskette in the grill side without any heat. depends on the sixe and the thnikness of the meat, you need approximately 12-20 hours before meat become tender.
here are few web site you can get some information
http://www.smoker-cooking.com/howtosmokeabrisket.html
http://bbq.about.com/cs/brisket/a/aa111503a.htm
http://www.wyntk.us/food/smoking-brisket.shtml
http://www.bbq-fyi.com/how-to-smoke-brisket.html
May 29, 2009 | Char-Broil CharBroil 4637318 Grill
Grilling Logo
1,746 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
