Hot water cycle flow problem
The hot water cycle just trickles into the washer, all other cycles work fine.  Even the cold water rinse that is part of the hot water setting runs fine.  we have replaced the hot water hose, but still have the same problem??  it is a top loading, model #82872810
  • 1 more comment
  • Jacqueline Amelio Apr 30, 2009
    Where is this water valve, is it located in the washer itself and why is it only the Hot Water? And I have 2 machines side by side and both trickle the hot water. Cold and warm water flow fine.
  • vgreunl May 01, 2009
    The hotwater inlet does not function
  • Anonymous Mar 27, 2014
    Whirlpool top load washer, warm and cold water cycles run fine. Only model number I can find is SM 82880869
  • 943 Answers
Hi thanks for the question their is a screen in the water valve to catch any dirt you can try and remove the screen in the water valve and try again if it works ok . it usually works thanks the appliance doc
Posted on Sep 24, 2008
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
Rinse cycle water flows out to a trickle- regular wash cycle flows normal- water valve?
Flows out where , drain or into machine ? If into machine , Most washers have a cold rinse into machine . If your using hot fill and you get a trickle , then problem is a clogged screen at the valve or a bad water valve .
Jul 06, 2009 | Washing Machines
No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Jun 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Hot water just trickles in both of my Kenmore top loader washers
Try reversing hot for cold hoses and see what happens. That will test your valves, hot water pressure, etc. As far as I know, the valve screens are right where the hoses hook up.
Apr 30, 2009 | Kenmore 22422 Top Load Washer
Rinse cycle, water won't work
It sounds like you either use warm or hot water for the wash cycle. If this is the case, you probably have a cold water solenoid problem on your water inlet valve (also known as a mixing valve on some washers). Most people use warm or hot water on the wash cycle. The water inlet valve has two solenoids. One for hot and one for cold. It uses a combination of the hot and cold solenoids to make warm water. The rinse cycle on most washers is a cold water rinse only, however. This would explain why the water appears to flow normally when it fills during the wash, and only trickles when it rinses. If you live in an area that has hard water, or if you use well water, these valves commonly clog with sediment. You can shut off the water, remove the hoses, and attempt to clean the sediment screens to see if the water flow improves. If it doesn't, you will need to replace the valve. The following link epxlains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
I know the link says this is for a Kenmore or Whirlpool, but also applies to a Roper. A replacement valve can be ordered on line at searspartsdirect.com. Just type in the model number and the part you need is located under the "Controls and Rear Panel" heading as item number 18 (part #285805). This is a very simple and inexpensive fix if you wish to perform the repairs youself. Not to mention, you can potentially will save hundreds by avoiding the labor charges of a service call. I hope this helps you. If you require additional assistance, please let me know. Hopefully, a good cleaning will do and you won't require parts.
Sep 12, 2008 | Roper RAS8445KQ Top Load Washer
No cold rinse
check to see that the hot and cold pipes are not crossed over
ie the hot pipe is on the cold tap
when machine goes into rinse cycle it only uses cold water
Nov 09, 2007 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
309 people viewed this question
Top Washing Machines Experts
