Question about NAD Audio Players & Recorders
Sound through one channel only.....NAD 310 Amplifier
Hi Guys,
I basically have perfect sound through one channel only. The speakers and cd player are perfectly fine with another amp all in stereo, so no setup issues here.
Im no expert but it doesnt sound too major, hopefully fixable. I bought the amp second hand so cant say of its history.
Thanks alot folks!!
  • 1 more comment
  • sircuit84 Sep 25, 2008
    Hi
    Thanks for the swift reply, I tried that before and the channel just doesnt output anything.
    I was wondering if anything needs replaceing. I read someone had a similar problem
    on a different nad amp, and they were advised to change a componant. Can it be fixed, maybe
    there is a reader out there who has had a similar problem?
    Thanks alot fixyathing!
  • sircuit84 Sep 27, 2008
    hehe:)
    I have some basic knowledge with electroics through my circuit bending. So I dont mind doing a bit of soldering. I would love to hear your logical approach:)
    thanks again
  • sircuit84 Oct 27, 2008
    Hi
    Can anyone help me please?
    Fixyathing can I hear your logical approach please:)?
    Thanks in adavance guys!
    Sergeant:
    Champion:
  • 341 Answers
If swapping of left and right input sources and left and right speakers does not help...you might have a bad channel in your amp.
Posted on Sep 25, 2008
  • jhun T
    jhun T Sep 26, 2008
    yes, it can be fixed by a qualified technician. If you done electronics before I might be able to help with a logical approach...or else you need to smell some resins...oppsss joke only :-)
  • jhun T
    jhun T Oct 28, 2008
    My first requirement for you is to get a shematic diagram (at least even a similar one will do). Since your other channel is working, it seems there is no dc voltage present in that bad channel or else it will trigger the speaker protector circuitry and cut-off the speakers' connection for both channels.
    Try to see if it has a fuse in the output or somewhat like a thermal cut-out device. You can also put a voltmeter in AC mode right at the output line of the bad channel amp. Put an input source and try to see if a signal is present in the output. If there is then a fuse or a device before the output to the speakers is in between it.
    Please update me on this. you can email me directly at jhunn06@gmail.com
    hope this helps..
Teac A R300 right speaker has s badly distorted sound after 20 minutes. When I turn it off nad turn it on again, Same problem after 20 minutes. Left channel working perfect.
Have you changed the speakers to see if it is a driver, or amplifier, issue? If it follows the speaker, get it reconed. If it follows the channel, look into that channel.
Aug 19, 2014 | Audio Players & Recorders
Setup help for record player (Pro-Ject Carbon Debut) and pre-amp (ART DJPRE II) into Denon AVR-1909. I have everything setup properly, but I cannot get the subwoofer to turn on with my 2-channel settings...
In two channel mode, there will be no subwoofer signal unless you change the front speakers to 'small'. If you set the front speakers as 'large' then the full frequency spectrum will be sent to the front speakers, and none to the sub. Switching from bluray may keep the surround configuration until you restart as you mentioned.
Sep 26, 2013 | Denon AVR-1909 Receiver
How do I connect a cd player to both a tv and an audio amplifier so Ican play either Cd's or DVDs?
Does the TV have a line audio outpot (red and white jack)? If so feed the amplifier input from there.
Dec 23, 2012 | NAD C372 Amplifier
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
My NAD C320 outputs a very low sound volume
Hi there I have a C340 that has similar problem, you must have bought this from ebay, lol.
Nad made a mistake on the C range, the pre - power link can be shorted out. if the pre is shorted out it takes out the pre amplifier stage, I have managed to get the right channel working, I will keep you informed what is the cause of the left channel. I have replaced the pre-amp IC and a couple of Jfets and transistors. Once I have repaired the Amp I could repaire yours if you like???
Apr 14, 2012 | NAD C320 2-Channel Amplifier
I have no sound from one channel. I have swapped speaker leads (sound just swops with the speaker). I have taken lead out of CD player and touched ends of leads for "earth hum". Only get hum on...
If the sound stays with the speaker, then the problem is with the speaker not the receiver (unless I misunderstand). You state that changing the speakers that the sound stays with the speaker. This means that both channels are producing sound, it is the speaker which is defective. You can verify this by using a 9V battery. Quickly touch the leads from the speakers to the battery. You should hear a pop or click. If the speaker is defecive, you won't hear anything.
Let us know what happens.
Dan
May 08, 2011 | NAD C350 2-Channel Amplifier
Do not know how to connect my kappa 60.5cs to my pioneer cd player do they have to go through an external amp?what do i do with the power plugs on the oppisite side why are there 2 per speaker
You need to run RCA cables from the CD player to the CD or AUX input on your amp / receiver unit. If you have a standalone amp, you need some way to control the volume. Basically, if you have a volume control on the front of your amp, you're OK. If not, you should also have a preamplifier that the CD player feeds first.
From the amplifier, then, a single pair of speaker outputs feeds a single pair of inputs on your speakers. The reason for two jack sets on the speakers is for "bi-wiring" or "bi-amping", not necessary for basic stereo reproduction.
So -
CD red/white RCA out -> preamp/receiver red/white CD/AUX input. Amp speaker output (red + / black -) to one red/black input pair on the speakers. An input on the speaker is side by side...
Keep the red to red, black to black when connecting the speakers, or you will wind up with poor sound and weak bass.
Jan 18, 2011 | Infinity US-1 Main / Stereo Speaker
I added a turntable to my system NAD 72296 receiver and the record played for two minutes before the receiver quit. Now I cannot even get the cd player (which worked yesterday) or radio to work . . .but...
hi,
check ur speakers first is it working or not. u said above that the sound is getting through the head phone. the headphone out is also coming from the main amplifier by reducing power using resistors. so amplifiers have no problem. also check is there is any switch for speaker A and B and is it OFF or ON.
ok
Dec 27, 2010 | NAD Audio Players & Recorders
990 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
