Question about GE (WMM317437) Answering Machine
GE 29815A answering machine rings
How can I change the number of rings on my GE 29815A answering machine before it goes to voice recording. It is now set at 3, not enough!
  • Anonymous Feb 12, 2009
    nesecito el manual de instrucciones del respondedor
    modelo 2-9815A
3 Suggested Answers
kimehselorio
  • 85 Answers
SOURCE: GE phone answering machine
please provide more information about this problem . thanks :D
Posted on Dec 11, 2007
SOURCE: lost instruction booklet
Go to
http://esupport.sony.com/US/perl/model-home.pl?mdl=TAM100
and look under "Support by Type" and you can download one under
manuals-specs-warranty.
Posted on Jul 01, 2008
Why won't the answering machine, when set to 'answer on' not record a message?.It goes to voice mail. Is my machine defective?
Maybe the answering machine is set to pick up at say"5 rings" and the voice mail is set to pickup at "4 rings" . Change the voicemail setting to a higher setting than the answering machine. That may be the problem.
Aug 26, 2014 | Lands Phones
My phone goes to voicemail after 3 rings. how do i change that to 5 rings?
do you have the phone with an answering machine like:
http://www.generalmanual.com/Telephones/GE-25932EE1-Cordless-5-8GHz-Edge-Phone.htm
Or are you using a voice mail system on your phone line? If so, contact the voicemail company or your phone company for information on how to change the number of rings before the forward.
EJ Kudelka
Apr 29, 2011 | GE 25932 Cordless Phone
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
Can I use cordless phone answering machine even if I have voicema
You do not have to cancel the phone company voice mail service. You need to change the number of rings the phone uses to answer the voice mail.
For example, if the telephone company voice mail answers if 4 rings, set the telephone answering machine to answer in 3 rings or less.
Good luck.
joequevedo@charter.net
Mar 03, 2009 | GE 27992GE5 Cordless Phone
How can I change the Rings to Answer setting to one ring?
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1.
Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
Get manual at http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Jul 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Lost instruction booklet
Go to
Jul 01, 2008 | Lands Phones
Instruction Manual
GE Digital Messaging System ~ Voice/Time/Day stamp
1a] press and hold down STOP/set button and wait for promps.....
ie. press NEXT to change Day stamp and then SET to pick.
ie. press NEXT to change Hour and SET to pick.
ie. press NEXT to change Minute and SET to pick.
1b] press NEXT to pick 1minute allowance recording for recieving messages coming in, or 2 minutes or 3 minutes or 4 minutes. This machine only has 1/2 hour of recording time, so maybe you can 'tell' -record- that and let incoming callers know they have only minutes and machine will automatically shut off and cut them off [hang-up] on them.
2] press and hold down Greeting button and follow promps to change the answering machine voice promps to your own voice. Machine will automatically PLAY BACK your voice, if you don't like what you hear, press and hold down Greeting button again and try again.
~ hope all above helps.
May 10, 2008 | GE 29888GE1 Digital Answering Machine
Phone rings many times with no answering message coming on and no messages recorded
I can't seem to get the security code entered.  It won't change.  None of the numbers will change when I try to set it up.
Jan 28, 2008 | GE 29878GE1 Digital Answering Machine
Number of rings
press *94, then press the number of rings you want 1-9. The tone will change and thats it.
Nov 29, 2007 | Siemens Gigaset S455 Cordless Phone
Cordless Phone
You did record a message on the answerer, didn't you? Mine displayed that until I recorded the outgoing message for the answerer. You do not need any service from your phone provider. The answerer in the base unit simply records the caller's message when you don't answer after a set number of rings. The manual tells you how to name the handset, which is a nice feature if you don't wish to use "unit 1, unit 2, etc".
Aug 28, 2007 | GE 28112EE2 Cordless Phone
GE (WMM317437) Answering Machine Logo
496 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
