Question about Kodak EASYSHARE 5100 All-In-One Printer
KODAK 5300 BLACK WON'T PRINT
I HAVE RUN A CALIBRATION AND NOZZLE CHECK WHICH WORK, BUT WHEN I TRY TO PRINT FROM A FILE I HAVE SAVED IT WON'T PRINT. ALL I GET IS A BLANK PAGE.
  • Anonymous Sep 25, 2008
    I have the same problem. I just replaced my ink cartridge and nothing will print anymore! I don't know what to do!!!
I had the same problem and i had to have kodak send a new printhead. that was a few months ago. i am now having the problem AGAIN!
Posted on Sep 26, 2008
  • Kodak Master
  • 32,281 Answers
Try removing the printer and reinstall it again
Posted on Sep 24, 2008
It will not print the black ink
Have you clean the printhead and reseating the ink cartridges?
heres the you need to do
-Reseat both ink cartridges
-Calibrate the printhead (Press menu button and look for calibrate printer to do it)
-Clean printhead (press menu then look for clean printhead choose deepclean)
-Press and hold Photo and copy botton at the same time to print your DEMO PAGE!
-If the black is absent it means the nozzles of the printhead is clogged you need to call kodak for printhead replacement Toll Free 1 800 421 6699. GudlucK
Nov 04, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
My printer will not print in black and white. i have already cleaned the print head and that changed nothing. my printer is a kodak easy share 5300
have you done the deep cleaning?If yes Please try also to Calibrate the printer.
Now if this solution did not solved your problem it means the nozzles of the printhead that you are using is already clogged Please call kodak for Printhead replacement Toll Free 1 800 421 6699
Nov 03, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black color streeks. Cleaned 3 or 4 times to get
it seems youu already did all the troubleshooting.
Heres the thing you need to do:
-Try to reseat the printhead then calibrate printer., you can calibrate printer by pressing menu scroll down and look for calibrate printer.
-Please download your latest firmware at kodak.com/go/downloads
If the steps did not solve the problem it means that the nozzles of the printhead is defective you may call kodak for repair Toll Free 1 800 421 6699., GudlucK!
Nov 02, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer will not print black ink
Seems to be a common fault with Kodak EasyShare 5100/5300
Contact Kodak Support and go though the following tests:
Remove and re-seat Printer Cartridge(s) - Done
Clean Printhead - Done
Calibrate Printer - Test Sheet Not Complete!
Run Computer Colour Test - Done
They will then send you a new Print Head.
Mar 25, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Black inkwon't print
pictures are not clear even after installing new ink cartridge and cleaning print head
Oct 04, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
BLANK PAPER IS COMMING OUT
Most likely your print head is clogged, there are 2,000 some nozzle's in it. If the printer is not used for a moderate amount of time the ink can dry up and cause a clog in those nozzle's. You can try reseating the ink cartridges(take them out turn off power, unplug printer, power back on & wait for it to get done making noise) then proceed doing a printhead clean from the main menu, or homecenter->?->maintenance. Then after that do a calibration, print a demo sheet to see if there is any improvment. The printhead clean pushes ink through the nozzles to try to clear clogs. The calibration scans those nozzles to see which are avalible to use, and makes sure that all the avalible nozzles are being used. If this does not fix the problem you most likely need a printhead but you will have to call kodak; as they are not avalible in stores. Also you can try updating your firmware from kodak home center, or www.kodak.com/go/downloads
Sep 01, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Downloading cd
Most likely your print head is clogged, there are 2,000 some nozzle's in it. If the printer is not used for a moderate amount of time the ink can dry up and cause a clog in those nozzle's. You can try reseating the ink cartridges(take them out turn off power, unplug printer, power back on & wait for it to get done making noise) then proceed doing a printhead clean from the main menu, or homecenter->?->maintenance. Then after that do a calibration, print a demo sheet to see if there is any improvment. The printhead clean pushes ink through the nozzles to try to clear clogs. The calibration scans those nozzles to see which are avalible to use, and makes sure that all the avalible nozzles are being used. If this does not fix the problem you most likely need a printhead but you will have to call kodak; as they are not avalible in stores. Also you can try updating your firmware from kodak home center, or www.kodak.com/go/downloads... As for the software issue I would try running the clear utilty program from www.kodak.com/go/clear and the try redownloading the software from the above link go/download
Aug 31, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Colors do not come out properly on #5300 changed ink and calibrated--HELP!!
Most likely your print head is clogged, there are 2,00 some nozzle's in it. If the printer is not used for a moderate amount of time the ink can dry up and cause a clog in those nozzle's. You can try doing a printhead clean from the main menu, or homecenter->?->maintenance. Then after that do a calibration, print a demo sheet to see if there is any improvment. The printhead clean pushes ink through the nozzles to try to clear clogs. The calibration scans those nozzles to see which are avalible to use, and makes sure that all the avalible nozzles are being used. If this does not fix the problem you most likely need a printhead but you will have to call kodak; as they are not avalible in stores. Also you can try updating your firmware from kodak home center, or www.kodak.com/go/downloads
Aug 31, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5300 not printing colors
Kodak told me to take the printhead off and reseat it several times, which I did. I then deep cleaned it, calibrated it, and replaced the color cartridge. It didn't solve the problem. Kodak will replace the printhead for free, and after I return the defective one, will send me a free color and black cartridge. Very nice service. I've been very happy with the 5300.
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
98 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
