For xerox work center 420
How to erase the flag (change drum) in copier xerox work center 420.........
after changing it.
thank you
  • 53 Answers
If you are using oem products than send it back they are reset with a chip within the drum unit
Posted on Jan 10, 2010
How to reset xerox m118 drum counter
Hi Laurynas Straksas,
What very frequently happens with those machines is this. On the drum cartridge, there is a green cover in front. Behind that cover there is a series of gears, one has a flag like tab sticking out. That tab is the drum reset, what it does is makes one swipe past the drum reset switch when you install it and that resets the drum life by swiping a switch one time. That flag has fallen and did not swipe your switch, you can do one of 2 things. You can have whoever you purchased the drum from replace the cartridge, or you can pop off that green cover and manipulate that flag to an Up and to the up position and replace the cover and install the drum in the machine, once the machine runs it will swipe the switch and reset the drum count, turning off the light and allowing your machine to run. Once you take the green cover off you will easily see what I am talking about, Flag will be down, work it until you get it in the up position. That will do it.
Aug 26, 2014 | Xerox WorkCentre M118 Black and White...
Drum cartridge problem is displaying on xerox copy center c128
U HAVE TO CHANGE THE DRUM CARTRIDGE OR IF UR A SERVICE REP U CAN ALSO CHANGE THE CHIP TO MAKE IT WORK
Aug 01, 2011 | Xerox CopyCentre C128 Black and White...
I needed a new drum (j2 error) so I bought one, installed it correctly, but the machine still shows the j2 error and will not clear itself or let me make copies. What can I do? I really need it to be...
Found old post for diffrent printer see if this info helps.
Drums may worj the same even though diffrent models.
Problem with the Xerox Printers Xerox XD130DF J2 error replace
By lgrey on Jun 20, 2008
Xerox XD130DF J2 error replace drum Best Solution posted 3 years ago
cbb7438.jpg rytech uk
  • Rank: Wiz computers_small.png
  • Rating: 80%, 98 Votes
Im presuming that your have replaced the drum??
if so :
Remove the new drum.
On the front of that drum, there is a green cover. Take it off and what has happened is the flag on the gear had dropped in shipping.
You will see a flag like piece of plastic on one of the gears, reset it to up and somewhat to the right.
Then put the green cover back on
That flag has to be in the up position when new. It passes down and actuates a drum reset switch on the machine.
When that is back in the up position. re insert the drum and on the first revolution it will turn on the switch.
Jul 06, 2011 | Xerox WorkCentre XL2140df Laser Printer
I have a xerox xc1040 copier. The paper jam light is stuck on (it is the red light in the center of the display). I have gone through the entire sequence of recommended steps in the Xerox PDF files for...
Sounds more like the drum life chip has expired. Either replace the drum unit or the chip .
I can't remember if the xc1040 has a chip, or if its the one with the gears on front that has to drop a flag in order to reset the drum count.
Either way, I believe replacing the drum unit is the solution to your problem.
Dec 13, 2010 | Office Equipment & Supplies
Xerox WorkCentre M15i, 1" streak/smudge on left edge.
It's probably coincidence, the problem is probably your drum unit, and it probably had nothing to do with being exposed to the light unless you had it out in direct sunlight, regular indoor lighting will not hurt the drum.
Apr 19, 2009 | Xerox 5100 Copier
I have a Xerox XC1020 copier and the drum light is on...
No, What happens is on that drum unit , under the green front cover there is a series of gears with a small flag on it. That flag makes one rotation when the drum is installed and actuates the new drum switch. What has happened is that flag has dropped while in the box and never reset the switch. You can pop that green cover off and reset that flag to the up/right position, approx the 2 o clock position,, Or you can exchange the cartridge. That is very very common on that cartridge for it to drop in shipping.
Mar 10, 2009 | Xerox CopyCentre C20 Black and White...
Xerox XD105F Have J2 Code, Replaced Drum and Code has not Gone away, How do I reset
On the front of the drum cartridge there is a green cover, Behind that cover is a set of gears , one with a flag like actuator on it.
Most likely the flag dropped in shipping and did not reset the drum replacement switch.
You can either try popping that cover off and resetting that foag to the up and right position or take the cartridge back for replacement.
Aug 06, 2008 | Xerox Office Equipment & Supplies
PHASER 8550DP
Your yellow ink sensor is stuck
Testing the Ink Out Sensors Use this procedure to test if an Ink Out Sensor?s flag works correctly.
1. Remove ink sticks from the ink loader?s channels.
2. Place the printer in Diagnostics Mode by:
Service method
a. Turning on the printer and as XEROX appears on the screen, press and hold the Back and Help button until Beginning Service Mode Initialization appears.
b. Scroll to and execute test Monitor: Sensors
Customer method
a. While error code displayed, press UP arrow and OK key.
b. Scroll to Troubleshooting: Service Tools: Enter Diagnostic Mode. (Printer restarts).
c. Select test 82: Monitor Sensors. Press OK.
d. Scroll to 01: Exit Diagnostics and press OK to return to customer mode.
3. Insert the clean eraser end of a pencil thru the lowermost oval slot. (The eraser end of a pencil closely simulates the bottom rail shape of a Xerox ink stick.)
Slide the pencil down the white channel guide until the sensor is tripped. A sensor change is displayed on the control panel. When the flag is depressed, the front panel will read <color> Ink Present H. When released, the reading will change to L. The test will only display a reading when a sensor change occurs. If a flag is stuck, no sensor reading will be displayed on the front panel. If it doesnt change states you need to replace the ink loader
Mar 08, 2008 | Xerox Phaser 8550DP Printer
105 people viewed this question
k24674
