Question about Acard Technology (CD1TO7T) CD-RW Burner
Blinking green light on 1 tray
After i turn the tower on the tray with the blinking light will not open,all other trays open except that tray
  • 32,281 Answers
You could have a faulty drive.
To open the tray, you need a paper clip, straighten it and place it in the small hole below the disc tray, push it in and the tray wull pop out slightly, remove paper clip and pull the tray fully out with your fingers.
Then try to close and open the tray with the push button, if it does not work you need to replace this drive with a new one.
Posted on Sep 24, 2008
Once my game is loaded into tray the screen comes up and tells me to open back up and close again. This occurs all the time not just with one game. Any suggestions???
Yes. First when the tray is opened watch the green light . It should
blink then stay on steady.
When the tray is closesing you should see a blinking
green light in the center of the ring of lights .When the tray
is fully closed and engaged the light will stop blinking then you
should hear the drive spin-up. If not open the tray then close
it ,just as the tray is almost closed push it close hard then the
green flashing light should be steady on.
This is cause mostly by friction in the drive or a bent
leaf switch that the tray engages to tell the console
the state of the tray .
The remedy is either you or a shop
will need to open the drive and remove the frictions
points which very from drive to drive. and check the
leaf switches . cost 40.00 or so . or you could
simply buy a "new" drive on ebay and swap the
Drives P.C. board from the old drive to the new one
price 40.00 but you supply the labor.
I gave you more info than you need but this is
common problem and I hope it will help others also
If you have any questions please feel free to ask
Rob
Nov 14, 2010 | Microsoft Xbox 360 Console
Acer laptop disc drive not opening w/ btn or paperclip
Turn the computer off.
Gently push the paperclip in until you feel some resistance.
Then, with a more-firm pressure, push it another 1/8 to 1/4 of an inch -- the mechanism should "unlock" the tray, and it should open, just very slightly.
Then, the tray can be grabbed, and gently pulled open, to its full range of motion.
Dec 29, 2009 | Acer Computers & Internet
The blinking green light is because your 360 is not understanding that the disc tray is closed. That's also the reason that the tray comes back open. It's not getting fully closed. Next time you insert a gamepush the drive closed with your hand. You'll know the drive is closed when the light stops blinking.
Dec 26, 2009 | Microsoft Xbox 360 Console
My xbox now have an blinking green light and the tray would come out
The blinking green light is because your 360 is not understanding that the disc tray is closed. That's also the reason that the tray comes back open. It's not getting fully closed. Next time you insert a game push the drive closed with your hand. You'll know the drive is closed when the light stops blinking.
Dec 23, 2009 | Microsoft Xbox 360 Console
THE ORANGE LIGHT IS ON AND NOT PRINTING
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Oct 02, 2009 | HP LaserJet 1320n Printer
CD tray will not work
mine has the same problem.
1. turn your xbox sideways
2. press the open disk tray button
3. hit your xbox on the curve, above the disk tray
it works for me
May 02, 2009 | Microsoft Xbox 360 Console
I have a HP LaserJet 1320n printer and it will not print. An orange light keeps flashing by the triangle with an exclamation point in it. I printed a test page and it was okay. It will not print...
Possible Solution to your issue!
Feb 23, 2009 | HP LaserJet 1320n Printer
Red and Green lights are together blinking continiously
I had this problem. The cancel button was stucked. Open the toner tray and slighly push the button side top-cover up. It released the cancel button for me (actually I was trying to open the top, but it worked). The cancel button was released and the blinking red-green stopped. Printer now working.
Mar 03, 2008 | Samsung ML 1610 Laser Printer
Minolta Dimage multi pro
Initially, I get a green flashing light when unit turned on, but after a minute or so, it turns to a red flashing light. It will take in the film tray only when blinking red, not when blinking green. My iMac has a hard time seeing the scanner, keep getting "scanner not found" messages. I have to go to system profiler and have it refresh and then it finds it, then the scanner software sees it too. But I have been unable to one preview out of it, says LED error and that's it. Using 10.4.10 on an iMac 20" with 2.5gb of RAM, using Pshop CS2 or going through Minolta Driver of OSX I got off of VersionTracker. I did remove the screw for transport right away. Will feed in 35mm tray with red blinking light, will not feed in 120 tray except partially with red blinking light, and only a couple times out of maybe ten tries.
Aug 23, 2007 | Konica Minolta Dimage Scan Multi PRO Film...
Acard Technology (CD1TO7T) CD-RW Burner Logo
272 people viewed this question
Top Acard Technology Computers & Internet Experts
Martin Murray
Alun Cox
DROPNDEAL
DROPNDEAL
Are you an Acard Technology Computer and Internet Expert? Answer questions, earn points and help others
