My rca tv keeps changing channels automatically. It also comes on and goes off automatically
  • 8,617 Answers
Whats the model number of your set Sounds like the small signal board, very common with the ITC222 and ATC221 chassis RCA's. Respond to this same post with your mode number and I will assist you with the problem.
Posted on Sep 25, 2008
When I turn on the TV the channels just keep changing on its own
depends does the channels goes up or down... if they go up the channel up button its making the problem or if they go down well channel down button.. just try to unstuck them it that doesnt fix it it means the button from inside the board its broken and you just need to replace that broken button and problem solved..
Oct 22, 2010 | RCA Televison & Video
Don't know what channel the dvd is suppose to be on. TV is set on 4 and I can't get dvd to change to four.
DVD players don't carry signals to channels. They carry signals to inputs. Check the back of your TV. If your cable coming from the DVD player goes into "video 1" set the tv to video 1, etc.
Sep 07, 2009 | RCA Televison & Video
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
RCA 32" TV
The most likely problem is a stuck tact switch, if it goes up in channel number, 5, 6, 7, etc. then the channel up button is stuck, if it counts down it`s obviously the ch. down button. Problem is you have to remove the guts of the set to get at the control boards screws, you can try turning on the set and poke around the offending push button with a tooth-pick, if it stops changing channels leave it alone and use your remote from now on to change channels, if you can`t get it to stop the tact switches or the control board module will have to be swapped out, hope this helps
Nov 27, 2007 | RCA F32695BC 32" TV
RCA F32668 model tv flicking channels on its own
Tuner Has Bad Solder Connections Internally
Nov 12, 2007 | RCA F32668 32" TV
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Televison & Video Logo
280 people viewed this question
Top Televison & Video Experts
