Question about JVC AV-48WP30 48" Rear Projection Television
I have double blurry vision with green and purple/red splashes on all inputs (ghostlike)
JVC av-48wp30 rear projection. It started yesterday but fixed itself and it was switching in and out between normal picture and one i am now describing but now it is staying with the blurred double colors on all inputs (even xbox). I have tried conversion page but it is doubled and blurry as well and i can even up the red and blue crosses but the green is way out of the area so i can't match it up.
Thanks,
hoag34@hotmail.com
    Novelist:
    Champion:
  • 203 Answers
This is a very common problem. If you want to fix this yourself you will need to be able to solder, but other than that its a very easy fix. Both the convergence output ic's need to be replaced (PN STK392-110). If you have a repairman do this for you it will run $300-$500 to repair. Let me know if you want to fix this yourself and i will assist you further.
Thanks
Tim Nolan
Posted on Sep 24, 2008
We have double lines of purple and green on screen. Please advise Thanks
Replace the convergence IC's STK392-110.
AND Check the resistors 1.6ohms and 2.2 ohms.. If open replace them.
Feb 01, 2011 | JVC AV-48WP30 48" Rear Projection...
Blurry vision on picture
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | JVC AV-48WP30 48" Rear Projection...
Looks like 3D Picture
You probly have a convergence cicuit failure. Replacing the convergencr IC's will probly fix it.
I recommend a professional repairman to
do it though. Particularly if it needs further adjustments after the IC's are replaced.
Jun 16, 2009 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 Problem
the best place for parts with free installation instructions is the following link. In fact its the only place that I am aware of that send s instructions with their parts.
http://servicemanuals.vstore.ca/
Apr 21, 2009 | JVC AV-48WP30 48" Rear Projection...
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Red lamp gives off ghostly blurr
Red convergence IC is bad...replace both STK IC for durable,
long-lasting repair..............................T.
Dec 24, 2007 | JVC AV-48WP30 48" Rear Projection...
Double vision
In this particular unit what you're describing is a failure of the convergence amps. This unit takes two STK392-110 Sanyo built Ic's and one or more 2.2 ohm/1w resistors for the yoke return. replace these and you should restore normal function after a little convergence touch-up.
It's not an expensive job in a qualified shop either. If any of this sounds a bit complicated take it in and have the job done.
Have a great day!
Bill
Dec 07, 2007 | JVC AV-48WP30 48" Rear Projection...
Jvc tv picture quality
sounds like your crt tubes...meaning Red, Green and Blue are out of alignment...or possibly 1 of the crt's is burned out.
Jan 29, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP74 48 in.
The convergence circuit needs repaired. I did the same job yesterday on this model. I not only replaced the convergence ICs, but, I had to replace a couple of resistors and a coil. The convergence alignment was minor after that.
Jan 22, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
153 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
