Question about Samsung SCX 4200 All-In-One Laser Printer
I JUST CAN SEE IN THE DISPLAY ERROR LSU. WHAT I CAN DO IT FOR FIX THE PRINTER
I CAN SEE  THE ERROR LSU IN THE DISPLAY
Sir I see the error of my printer kindly make me answer for LSU ERROR
thanks
raju kale
Posted on Sep 26, 2008
Call service Code 4600 KYOCERA FS 8520 MFP
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
May 17, 2014 | Kyocera FS-C5030N Led Printer
LSU ERRORS DISPLAYED ON SAMSUNG SF565PR WHILE COPYING?HOW TO FIX IT?
LSU ERROR on this machine means that the Laser Unit is fauly and needs to be replaced.
You can call for a tech or can take the printer to a printer service.
Jun 03, 2011 | Samsung SF-565PR/XST Printer
Display reads E-7 03 error code
E7/03 is a lsu error. The LSU is the “printer head” of the printer. But instead of emitting ink, the LSU emits a laser beam, directing it at the drum of the toner cartridge. If replacing the lsu does not fix it it may be the mcu pwb, but most likely the LSU.
May 11, 2010 | Sharp AR-507 Copier
Have lsu error also.
Hi ...
LSU stands for Laser Scanner Unit ... you normally get 2 different kind of errors with LSU ...
LSU Hsync or LSU Motor Error ...
If you get this error, it means that the Laser Scanner Unit has gone bad and the only way to get it fixed is to get the printer repaired ...
Cheers ....
Jul 28, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Error message w/Samsung ML 2150 Laser Printer - Engine LSU Error
Your Laser unit at the top section where the paper exit is faulty. You have no choice but to change it.
Nov 11, 2008 | Samsung ML-2150 Laser Printer
LSU ERROR shows in display panel
The LSU is the Laser Scanning Unit or "printhead". There is a mirror in there that spins really fast, if the mirror spins too slowly (bad motor, low voltage) it gives an error. Sounds like you would need a replacement LSU. Have the printer serviced.
Jan 02, 2008 | Dell 1600n All-In-One Laser Printer
LSU Error
LSU (Laser Scanning Unit) is a device inside the printer that create images on the drum.
If you see LSU Error on the display, it is indicating that there's a problem with LSU unit.
  • Unplug the power cord and plug it back in.
  • Check if the printer makes any humming noise.
If the problem persists or does not make any noise, LSU needs to be replaced.
If your unit is under warranty, please contact our tech support at 800 - 726 - 7864.
Otherwise, please find nearest Samsung Authorized Service center from the link below.
Dec 06, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
451 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
