Question about Symbol MC9060-G
Is there a way to disable the Bluetooth and WiFi at an administrative level?
We are using the MC9090-G (RFID) on a military installation that will not allow WiFi or Bluetooth technology to be active. I know how to disable them, but Security is afraid that one of the operators will enable these options at will. Is there a way to disable these options...either by an admin setting or removing a driver or file that's required to make them work?
  • 77 Answers
Install a program called symbol appcenter and you can keep people from accessing anything you do not want them to access, I have it installed on mine for an inventory system and all my employees can access is the inventory system. As the administartor I have the password if I need to access anything else in the scanner to ake changes, but nobody else can.
Posted on Feb 26, 2009
Cracked scanner glass on lower housing of symbol mc9090-g
Support contact:
https://portal.motorolasolutions.com/Support/...RFID...
Mar 08, 2013 | Symbol MC9090-G RFID Handheld Barcode...
Hi my MC9090-G wont power on.
On an MC9090, with the battery removed, hold both power and trigger down, then insert the battery, and keep holding both buttons down. Wait for the onscreen display.
Feb 28, 2013 | Symbol MC9090-G RFID Handheld Barcode...
Can you improve the screen touch sensativity on a MC9090-G RFID?
Quick answer no you can't. The touch screen is a resistive panel and hence you may get panels with slightly different tolerances, but that’s about it.
If they are old and worn they do tend to need a bit more persuasion to work and once they stop working they need replacing.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Jun 08, 2010 | Symbol MC9090-G RFID Handheld Barcode...
How to configure Function keys on MC9090 from ITS service
my problem is in the configuration of symbol MC9090 in comunication with sap when send function Key ( F5) .
Question .
What the value that the SAP waiting this process?
May 17, 2010 | Symbol MC9090-G RFID Handheld Barcode...
How do i restore mc9090 to default?
Hello sburrell. By reset to default, do you mean reinstall the Operating System and completely start over? If so, just contact Motorola/Symbol or the vendor you purchased the unit from and get the exact Operating System type and version for your MC9090. Then you can download the correct OS installer from Motorola/Symbol. The packages come with a "readme.txt" that will instruct you on how to install the OS. I hope this helps. Good luck!
Dec 14, 2009 | Symbol MC9090-G RFID Handheld Barcode...
Getting a MC9090 and 1500 preprinted labels to stick on pieces of pipe. Just need an excel file with the cross ref in it. Want to scan a barcode later and have description come up. Can I do all of this in...
To get scanner to work on MC9090 WM5 and scan into excel, I had to install DataWedge From Here You will need to install this through your ActiveSync That will make it so you can scan directly into excel The setup your data, the you can do a find, to find the cross ref
Dec 10, 2009 | Symbol MC9090-G RFID Handheld Barcode...
I replaced a Symbol MC9090. How do you configure it
The RFID version requires a fair bit of knowledge and an application that is RFID capable. Contact your dealer. If you bought it used or off the web, good luck. Your best bet is to contact the Help Desk at 1-800-653-5350 or work with a full service dealer in your area
Oct 24, 2009 | Symbol MC9090-G RFID Handheld Barcode...
MC9090 Motorolla RFID Create images
I presume this is if teh battery is removed for a significant ammount of time so the terminal cold boots.
What you need to do is download from Motorala/Symbol is
StartUpCtl
this will allow you to reinstall programs automatically after a cold boot and also auto run them.
Download the application and read the instructions, its very easy.
If you need any further assistance then please contact us
Aug 28, 2009 | Symbol Motorola MC909X-G Series Portable...
Could not active it the scanner on the MC9090
The link works for me DataWedge provides a convenient mechanism for non-scanning aware applications to receive data from embedded or connected data capture devices. It allows the user to capture data into any application that accepts keyboard input. It supports four types of Data Feeds: Barcode Scanners, RFID Tag Readers, MSR Readers and Serial Data Input. It provides user with text/hex data formatting and prefix/suffix facilities. Description
  1. New Test and Log Display.
  2. Improved DataWedge Startup Time for MSR and RFID
  3. Gen2 RFID Support
  4. Device enable/disable persistence over cold boot
  5. Virtual Key Support in Prefix/Suffix
  6. Performance improvements for MSR
  7. Enable Serial Interface on startup
  8. Support added for Event based Serial reading.
  9. Delays regarding RFID are fixed.
  10. Several Barcode character mapping issues fixed.
make sure some security software is not blocking your access
Jun 22, 2009 | Symbol MC9090 Barcode Scanner
Symbol MC9060-G Logo
410 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
