Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Lift links There are 2 lift links on the deck. One broke and one broke at sometime and is gone. Where can we see a parts manual to see if this is the true name for the part and the # OF THE PART.
I have order this part from sears after breaking. Left hand lift link 139865, right hand lift link 139866.
Posted on Aug 11, 2009
    Problem Solver:
  • 5 Answers
I imagine the lift links to be a piece of steel with a couple holes in them. Ask a local welding service to make your lift links. Typically you will not find part numbers for a part so eazily reproduced.
Posted on Oct 24, 2008
4 Suggested Answers
  • 10865 Answers
SOURCE: Deck adjustment lever broke, need part or manual
go to sears.com and you can get the manual and the parts you need.
Posted on May 21, 2009
  • 4 Answers
SOURCE: 26 HP, 48
fdgdfhhgfhh gfh dh hh gh fgdh hfg h
Posted on Apr 27, 2010
SOURCE: The mower deck clutch cable broke so blades will
I just got the kit 175067. Have the old one off except for where it's attached to the lever, schedule and weather has kept me from going further. Very simple to reconnect things at the pulley and above but not too sure how to connect the rest onto the lever and haven't had a chance to get a good look at how the old one might be connected yet. Should be a simple fix.
Posted on Oct 19, 2011
Craftsman riding mower 17hsp. older model,how to adjust mower deck, it scalps my lawn.
which one,there are a few ways to adjust it,1,there is a knob on the side by your foot with a gauge in inches,turn that to raise it to the desired height,with your release lever down,that is where you want to check for height,if that doesnt work,pick deck all the way up,unbolt each wheel and drop them down to the bottom hole,try that,if it still isnt right,there are 2 bars on the front of the deck,they should be in the middle holes,you can tighten them a little,but,that will affect the drive belt,dont play with those unless the nose is too low,if none of that works,there are 2 bars that clip tp the deck and hang on 2 bolts it is the lift system,you can tighten the bolts on those to lift the deck also.if i knew the number i would be able to have pics and diagrams for you,i believe it is, Craftsman 917.27318
Jun 02, 2015 | Craftsman Garden
Lever to lower and lift blade deck doesn't work. looks like mechanism that you push in on lever lost a bolt or something. deck doesn't lift or lower
Most of these mowers comes with an owners manual and in the manual there is also a parts description, look there. If you don't have the manual, go to cub cadet website.
Mar 25, 2015 | Cub Cadet Riding Lawn Garden Zero Turn...
How do I get incline to go back down manually
Hi Holly, please let us know what model of treadmill you have. Basically, there should be a 3-pin connector from the lift motor to a 3-pin plug, with rather large pins, near a couple or Triacs (Transistor looking things) that are bolted together. If you find this correct, you can turn off the treadmill, carefully reverse this cable 180-degrees, and theoretically you will be driving the opposite winding of the one causing you to lift incorrectly. This only gets the deck back down, and won't stop your troubles, as the assembly will now be trying to drive the lift down.
There can be a few causes...
1) "Up" lift button stuck
2) console electronics gone haywire(unusual)
3) lift assembly feedback lost, missing, incorrect(bad lift)
4) failing control board Triacs(either/or failing causes trouble)
Lasstly you can contact jatinah electronics for additional help. Good Luck!
Jan 20, 2015 | Nordic Track Exercise & Fitness
In search of deck diagram for Dynamark A3912-011
did you put all the metal lift arms back into the lifing tabs. check and make sure.
Jun 26, 2014 | Yard Machines Garden
Why does only part of my control for catnapper power lift chair work
The plug can be disconnected from the box. There is a box that connects the motor, the remote and the lift. Make sure all connections are together..
May 19, 2014 | Home Meridian Comfort Lift Recliner
I have a Craftsman model 917.273482 and the deck is riding on the left wheels when it is in the fully lifted position. What did I break in the suspension of the left side I can't see anything wrong.
from the manual I just looked at,, the wheels attach to the deck on that model,, so some part is misaligned or bent,, here is the page showing the deck and wheels,, maybe it will help you http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273482/0247/1509200/P0308003/00010?blt=06&prst=0&shdMod=917273482 You can look up the entire lawn tractor at searsdirect ,, Hope that helps Please take a moment to rate my response Thanks Good Luck
May 28, 2011 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
143 people viewed this question
Top Craftsman Garden Experts
Dwain Pippen
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
