Question about Nokia e65 Cellular Phone
Memory card problem for E65
Got 2gb micro sd card for E65 but it keeps saying disk error ?
  • 51 Answers
Format card by using card reader with fat16 file system
Posted on Sep 25, 2008
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
My memory card has been locked i dint keep any password i conneted to pc and clicked format but it says insert a disk plz solve my problem
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Nov 12, 2010 | Kingston 2GB Secure Digital Memory Card
Micro sd
Please try to insert it into another computer if the same error prevails uou have to replace your micro sd its bad.
Apr 30, 2010 | SanDisk 1GB microSD Memory Card
Cannot delete in transcend micro sd 2gb memory card.
hi if you look on one side of the disk you will see a little white switch ( very small ) move this in the opposite direction of where it is and that should sort you out....hope this helps please vote thanks
Mar 24, 2010 | Electronics - Others
Iam trying to download music on my sandisk micro card and it keep saying card is protected unprotect or use other disk
If you look at your micro sd card check for a switch that you can move. Move it in the opposite direction of that it is currently in. If this doesn't work try to change the switch on your sd adapter as well. If this still doesn't work switch the micro sd switch back to original state and try again. One of the cards has the lock activated. You just have to figure out witch one.
Please rate!
Cheers
Sep 28, 2009 | SanDisk 2GB microSD Memory Card
Micro sd memorycard
there are virus on our sd memory card. you must scan first and then format it. be sure scan and format in the computer.
Aug 10, 2009 | Cell Phones
My SD memory card says its "unwriteable"
There is usually a switch on the adapter you are using that is there for write protection. The Micro sd card does not have one. Make sure it is not in the lock "position". See this website for more on memory cards and common problems. http://www.retire-asia.com/microsd.shtml I cut a little piece from the site that might help you
"There is no switch on the Micro SD card itself, but a standard-size-SD adapter (which the MicroSD needs to be plugged into for use with a card reader) and SD cards such as the SanDisk 4/8GB have a sliding write-protect switch similar to a 3.5 inch floppy disk. Data cannot be written if the slider tab is in the 'lock' position. The tab could be damaged or missing altogether. This is probably the first thing to check if you have an SD card write error problem. Using sticky tape (Scotch tape etc) to cover the switch slot might solve this problem, but it may need two or more layers before it works. Some SD adapters need the tab to be placed somewhere between the lock and open positions before data can be written to the card."
Mar 03, 2009 | SanDisk 2GB microSD Memory Card
Formatting micro sd card
i'll make a try:
i) remeber u must have kept any password to micro sd card when the card was in samsung mobile g600 and keeping password to the micro sd card will prevent it from using in other device or even in other mobile phone
ii) so you have remove the password of micro sd card by keeping the card in tsamsung mobile g600 and use the option remove password(the way u kept password or by clicking 'option' when u highlight ur memory card)
Thanking you
M. Sridhar
Dec 31, 2008 | Electronics - Others
Copying pictures from computer to memory card
i have seen this error and i dont know why it does that. you may want to try buying a micro disk setup that fits into a sd adapter that will fit in your camera.
then you can take out the micro disk when full and put it on a usb adapter and plug right into a usb port.
i know this sounds like more work but so far i havent had a lock up on that or error yet. go to tigerdirect.com if you want to see the different adapters for the sd disk and micro disk and usb etc....
maybe this might help
Jun 22, 2008 | Kodak EasyShare C330 Digital Camera
Memory card micro sd cannot format
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
Mar 19, 2008 | RIM BlackBerry Pearl 8100
Nokia e65 Cellular Phone Logo
253 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
