Question about Frigidaire FEF455BB Electric Kitchen Range
Switch light replacement frigi gallery smooth top oven range
Existing switch is pushed into body. how do i disassemble to replace switch pt#318089910. my oven range slide in md# fes388wgcc was purchased used so i'm not sure of repair history. mfg date 1999 canada. the switch also controls convection fan which doesn't work. i hope the switch wasn't pushed in to intentionally disable. i have oven in my garage while testing/repairing
4 Suggested Answers
  • 447 Answers
SOURCE: need a book on how to cook with convection oven
Go to dealer you bought it at, and get one. If it's used, go online. There might be one you can download. If not I'm sure you can buy one there, if the unit is not that old.
Posted on Apr 07, 2010
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
Posted on Sep 05, 2010
  • 557 Answers
SOURCE: I have a Frigidaire smooth top range with
make sure you have 220 voltage to the stove
Posted on Oct 20, 2010
  • 552 Answers
SOURCE: MY 6 year old Frigidaire Electric smooth top,
This means the burner switch has failed or the control. remove hte back panel and investigate, more often than not the board goes bad on these.
http://www.appliancerepairlesson.com/
Posted on Mar 08, 2011
The control panel lights do not work nor does the oven. all the burners work fine this is a convection oven with a smooth top Gallery series
Check your main breaker in the fuse panel, it may be partially tripped. Turn the 40 amp breaker off and back on. if the display does not return to the stove, the I would suggest you contact a local servicer.
Aug 29, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Red light indicating a plate is hot stays continuously on.
I assume this is a smooth top model? One of the sensors on a burner is bad and can be replaced. It involves removing the top adn disassembling the burner. Not difficult by my standards but delicate work that requires some knowledge of electrical components.
Eric
Nov 12, 2009 | Kitchen Ranges
The oven does not heat up. broiler and cook top is working.
Check to see if the oven elements work, take out the racks and check if the black tubes on the top and bottom have ripped.
Aug 05, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Range with Error Code F5 E0
HI.The Door switches do not agree (condition exists when door switch is closed indicating an open door, and latch switch is closed indicating a locked door)
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Jul 18, 2009 | Kitchen Ranges
I have a Frigidaire smooth top oven. Oven door will not close completely and the oven light is on 24/7. Any suggestions?
Check the gap on the side of the door. Most likely the top will be wider than the bottom. There is a bulliten for several models. Call a service/parts dealer. Give them your model and serial number they can check the bulliten and order the correct hinge kit. The hinges and receivers will need to be replaced. Both must be replaced to correct problem. Not a difficult repair. If no one will hepl you, respond back and I can check the bulliten and get you a part number. And can order and ship you a part if necessary.
Apr 17, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Oven shut down in mid use and locked the door. Display said it was on self clean and then switched to error code F1. We have tried unplugging, cooling, cancelling and timing down the clean cycle. This...
f1 error is generally a fault within the electronic control/clock assembly. i wouldnt want to dump the unit just yet.get the model number and look up the control probably $200 or less.
Nov 11, 2008 | Frigidaire FEF365AS Electric Kitchen Range
Frigidaire, Gas Oven Door
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Oct 10, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Whirlpool RF196LX Smooth Top Range
4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Oct 21, 2007 | Kitchen Ranges
Frigidaire FEF455BB Electric Kitchen Range Logo
127 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
