Question about Gestetner Office Equipment & Supplies
Hi, Got a problem with Gestetner DSc38 document feeder. It will grab everything at once. Already changed the nessessary parts "Paper Pickup Roller, Separation Roller, Paper Feed Belt " still got the same problem. Is there somthing else that I missed? Any help will greatly appreciated. Thank you in advance!
    Novelist:
  • 170 Answers
If you already changed out the separation roller and the pick-up roller and your still having the issue then logically it sounds like a paper problem where they may have got glue on the edge of the **** and they're all sticking together or on the separation roller there is usually a small clutch like mechanism that sits right next to the roller which may not be doing it's job anymore. Can't think of much more that it could be, hope this resolves your issue and if so, please mark as a fixya... Dan
Posted on Sep 24, 2008
I am trying to print a label through the document feeder and keep receiving error messages on my Brother MFC9320CW AllInOne Printer .."Open the Top cover and pull out all 4 drum units completely and...
Try putting more than one sheet of labels in the paper tray. Even if you're printing one label, it helps the printer grab the paper without that error somehow. If you're already using more than one sheet, I don't know. Good luck either way!!! :)
Jan 18, 2011 | Office Equipment & Supplies
Doc feeder failure
clean the pickup rolls using alchole
Mar 21, 2010 | HP Office Equipment & Supplies
Paper is getting jammed in the document feeder
This problem occur due the DF is not detecting the Orginal size.
Check the Size detection sensor,located when u open the ADF cover u can see, Clean the sensor by blowing.
Aug 12, 2009 | Gestetner - DSm675sp Digital Imaging...
Document does not feed
Pull up to open the document feeder. Clean rollers and pad with alcohol.
Jun 09, 2009 | Brother IntelliFAX 2800 Laser Fax
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
Auto document feeder
Did you make sure the tape is removed inside the Document feeder,or maybe you need to check to see if anything is stuck in the rollers. Open the door (if you have not already done so) to the document feeder and you will see pictures on the inside showing how you can remove and/or change the roller (make sure everything is put back as the picture. Good luck, I hope that is all that is wrong with it.
Dec 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Color registration
Whenever you change the fuser unit you have to do the fuser registration.You have to use the manual feed tray with A3 or 11x17 paper for this registration.The details should be inside the new fuser box carton.
May 16, 2008 | DSC GESTETNER - DSc38u Color Printer
Gestetner dsc38 error code
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Feb 21, 2008 | DSC GESTETNER - DSc38u Color Printer
Document feeder
Its most likely to be the pickup roller and separation pad which will need replacing. as a short term fix try cleaning them with some isopropyl alcohol
Sep 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
91 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
