Question about MTX421D Car Audio Amplifier
AMP troubles Why would my amp keep blowing fuses every time i stick it in
  • cnnn_crts Sep 24, 2008
    Why would my amp keep blowing fuses every time i stick one in ?
  • 35 Answers
Most likely you have a bad ground, Take all the wires out running to it then put the fuses in, check you ground, then install everything back
Posted on Sep 25, 2008
My GMC Envoy keeps blowing the 10 amp fuse for the heaters.I unplugged the front blower fan but it still does it. Is the other fan in the consul?
The fuse isn't for blower motor. I saw a fuse 39 and fuse 36 both 10 amp, both for hvac. I don't know which one is blowing? One fuse is for actuator doors under the dash, the other is battery voltage to hvac control module. One is hot all the time, the other goes hot with key on.
What is model year? Does it blow as soon as you turn on the key? Any applicable hvac trouble codes? About all I can do is track wiring circuits.
Nov 08, 2017 | GMC Cars & Trucks
Why i keep blowing a fuel pump fuse?
Hey Paula, if it keeps blowing that could mean a short in system or more so the pump is having trouble pumping it is 20 years old also check the fuel pump relay
Oct 17, 2014 | Cars & Trucks
Fuse keeps blowing
Once a fuse blows & you replace it-- ONE Time--
then you stop
You go to wiring diagrams of the circuit with the
blown fuse & start your testing
Aug 11, 2014 | 1994 GMC Sonoma
I have a problem with my uniden cb with nitro 300a amp. The amp keeps blowing fuses immediately when I turn it on and I do not know how to trouble shoot the problem. Any help will be greatly appreciated.
hello is it the fuse along the cb line or the amp line if its blowing on the cb line you will need to get a 5-7amp fuse or even 10amp to be safe ,do the same with the amp this should cure the problem
Oct 29, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
2000 Jeep Cherokee #7 10 amp fuse
You will have to check the positive wire of the wires that go to the parking and side marker lights for a short to ground.Check the easy things first like the bulbs for these lights.It could just be a shorted bulb.You can remove one at a time and see when the fuse stops blowing.You an get a short finder from a part store and save the trouble of getting a bunch of fuses.Hope this helps.Good luck.
Mar 15, 2010 | 2000 Jeep Cherokee
New dryer keep blowing 30 amp fuses
your problem (especially if you are using screw-in "plug fuses") i.e. BUSS fuses and cartridge fuses they get hot and with time the insulating disc that insulates hot from neutral (grnd) breaks down and with dryer current draw it arcs over and in summer its more humid which contributes to moisture,have a new sub(pony) panel if you have no room for another 240volt circuit in your main panel,that should cure your trouble
Jul 19, 2009 | LG DLE5955 Dryer
Im having trouble i keep blowing fuses on my amp?
you have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
Apr 13, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Amps
If the amp blows a fuse with no remote voltage applied, the amp has a short in the primary side of the power supply. If the fuse only blows after remote voltage is applied, the amp probably has shorted output transistors.
May 02, 2008 | Boss Riot 1500D Car Audio Amplifier
MTX421D Car Audio Amplifier Logo
44 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
