Question about Microwave Ovens
How do I change the door panel on a Ge mocrowave
  • Microwave Ovens Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 25, 2008
It is a GE microwave that says reset filter
Open the microwave door and press the access panel above the cavity opening where it says "PUSH" to lower the panel door. Models with an Upfront Filter have a Reset Filter notification light on the control panel to indicate when it is time to change the filter. The Reset Filter reminder will light every 6 months.
Sep 16, 2017 | GE Microwave Ovens
Why wont my mocrowave run?
If the light on the control panel and the light inside are on when door is open the unit is probably dead, however if no lights anywhere on the unit you could have a tripped breaker in your house or a bad wall receptacle.
Aug 16, 2014 | Microwave Ovens
Why will my Kenmore model 401.85053010 mocrowave door will not latch?
Check the door latches that stick out from the door. Push them up. Is there any resistance? If not, then the spring that pulls them downward either broke or came of its catches. You will need to call a repairman who will have to take the door apart and either replace or re-fasten that spring.
Jun 11, 2014 | Kenmore Microwave Ovens
Ge mocrowave wotn cook, turn table wotn turn
I would suspect either the bottom or top door switch, or that switch's mount is loose, broken, or misaligned.
If you had posted the full model number, i probably could have told you which switch.
http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 05, 2013 | GE Microwave Ovens
Food not heated in mocrowave
I'd say the actual microwave generator has gone bad.
Jun 05, 2009 | GE XL1800 1100 Watts Microwave Oven
Ge spacesaver turntable will not turn
my mocrowave turntable will not turn but it will heat up.
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave light and timer work, but no cooking
IF IT TURNS ON AND SOUNDS LIKE ITS COOKING IT IS PROBABLY THE HEART OF THE MICROWAVE THE RADIATION PART WENT OUT IT IS MORE RECOMENDABLE TO REPLACE THE WHOLE MOCROWAVE
Oct 03, 2008 | GE JVM1850 1000 Watts Microwave Oven
My mocrowave fell and the front plastic on the door broke. The inside is not affected. Is it safe to use the microwave
The front plastic bezel on the door does not provide any shielding from the microwave energy inside the cooking compartment. As long as that is the ONLY damage and you haven't compromised the door, door frame or protective gasketing around the door opening then you should be safe.
Sep 14, 2008 | Microwave Ovens
I NEED TO INSTALL MY OVER THE STOVE MICROWAVE.THE MOCROWAVE HAS A MOUNTING PLATE AND I DO NOT HAVE IT. I NEED TO ORDER ONE AND HAVE CLEARER MOUNTING DIRECTIONS
You can download GE owner's manuals and installation instructions here.
Also for GEs, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If yours is not a GE, please reply back with your brand and model number so we can help you.
Aug 19, 2008 | GE Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
