Question about Pioneer SX-205 Receiver
Overload my reciever promps overload after turning on,as soon as i touch the volume,it prompts turn off power. i've got a pioneer sx 205 reciever. sure,'s got a few mile on it,... but only as of recently have i had problems. i can't turn the volume past a certain piont anymore when i get an overload message and the system cuts out momentarily, when i turn the volume down.i've tried moving the system and the speakers to shorten the lenght of running wire. only a small fan with direct airflow offers little help to this problem. i've blown it out with compressed air.that did'nt help. i'll try cracking the case next to look for an accumulation of years of built up gunk..if that don't work....i'm tossin' it !
  • cbntmkrjp Apr 01, 2009
    actually a bit more troubleshooting finally revealed the
    source of my problem. the reciever itself is perfectly fine.
    the culprit was the speaker. just inside where the wire
    connects i discoverered a capacitor that had literally
    exploded ! thus reducing the amount of current allowed
    to pass,promting the overload at a certain volume.
    total repair cost.....about two dollars and five minutes !!!!
Have you checked your wiring connections? Wires could possibly be touching each other making it short out and giving you that "Overload". If not that then I would say it could possibly be a fuse that has gone bad inside. ??? Just some suggestions. The reason I say that it could be the wiring is because when I hook up a system and the wires accidently touch each other it overloads the system past a certain volume. Again I would check my wires first and move on from there.
Dan Colton, Ca
Posted on Apr 01, 2009
My pioneer overloads and cuts out
this unit draws alot of power if you have too many things plugged in on the same circuit then it will shutdown and reset itself. unplug reciever and plug straight into the wall
Nov 13, 2011 | Pioneer SX-315
Blown Fuse / SX - 205 / Pioneer reciever
Check the area where the fuse's usually marked on the board or next to the fuse holder. Check the size also, 2 types 5x20mm or 1/4x1 1/4 in. Usually slow blow.
Mar 30, 2010 | Pioneer SX-205 Receiver
Pioneer Receiver SX-205 flashing ''overload''? Nothing in owner's manual troubleshooting chart.
usually it is a technical indication of the output being shorted. disconnect all speaker wires and try again. still blinking?
Mar 06, 2010 | Pioneer SX-205 Receiver
When i moved from home to home my reciever didn't do it. There where now cables conected and when i put him on he says within a few seconds OVERLOAD could it be the transistor?
may be Output transistors are blown on one side. NTE replacement P/N = NTE2329 & 2328. They are about $10 ea. You'll have to take an Ohm meter to figure out which one is shorted.
Mar 02, 2010 | Pioneer SX-205 Receiver
It gives an overload message regardless of what l have turned on
Check that the speaker wires are securely connected to the binding posts, and if you are using bare strand wire on them that there are no loose strands that can touch the chassis or other terminals or other wires.
Also check that your speakers are of a compatible Ohm rating for the unit. If you have any equalizer, tone controls or "bass boost" effects enabled, turn those off. They all require more amplifier power, thus possible overload can result.
Feb 08, 2010 | Pioneer SX-205 Receiver
"muting" shows up the screen and I no longer get volume, can not the muting off as I can not see where I would change that setting.
Are you sure it's not the TV telling you that it's muted? I went down the tubes on that one myself.
The receiver's Mute can be defeated by just rotating the volume knob upward. Ditto with TV's.
May 11, 2009 | Pioneer SX-205 Receiver
internal wickman fuses blown check speakers high unts tweeters\ gone short primary transistors /ic blown
Dec 31, 2007 | Technics SA-DX940
Pioneer SX-203
a little bit foolish thing: see if you have both the speaker channels (A and B) down. if you have both down it doesn't work - didn't for me.. and obviously make sure you have the right letter down - same outpout as your boxes
Dec 06, 2007 | Pioneer SX-205 Receiver
Pioneer SX-205 Receiver Logo
280 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
