Question about Gateway 7320GZ Notebook
Laptop will not boot
Laptop turned on and booted fine until I changed to power button board that was broken. Now the blue light goes on but the computer will not boot. Tried a different power button board but still no luck. Fans are not spinning, totally dead. All I get is the blue light.
    Problem Solver:
  • 50 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
15
Posted on Jul 25, 2009
I have a acer aspire 5920 the amber light comes on but when I try to turn the computer in the blue light lights up then goes off and will not turn on! Pls how can I fix this??
One suggestion I could offer is to unplug the laptop and remove the battery, then proceed to hold the power button for 20 seconds and then attempt to boot the laptop again.
Sep 17, 2013 | Computers & Internet
When i boot up power button on monitor goes on off resulting in flickering picture.
hi look for a bulging or bad electrolytic capacitors in the PSU board which cause the output voltage drop, usually 1500 uf/ 16v.just replace those bad cap then it will resume to normal operation good luck thanks for consulting through fixya.
Jun 23, 2012 | Computers & Internet
Broken power button
How did the power button get broken? What do you mean it's broken?
Are you saying nothing happens when you Press the Power Button? If so try the steps below:
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the battery, Remove the cover that houses the memory then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 16, 2012 | Gateway NV5378u Notebook
Acer power button
What do you mean it is broken? Is it physically broken? Or are you saying that when you press it, the laptop does not power on and boot up?
If it is physically broken then you can remove the strip that is above the keyboard that houses the the power button. To remove the strip, remove the screw from the bottom of the laptop, remove the battery, and remove any screws that are inside the battery compartment. Once the screws are removed you can pry the strip above the keyboard off but be careful because a cable might be under the strip. You can actually press the button on the board that the power button would press with your hand to power the laptop on.
If you are saying it does not power on when you press the power button try the steps below.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 13, 2012 | Acer Aspire 3680 Laptop
My Compaq Presario F756nr will not turn on. The blue light to the power cord is on and blue light on front of laptop is orange but when you press the power on button it comes on then goes right off.
Hold the Power button and at the same time attempt to continually press the button for the CD/DVD drive. Continue until the status lights for power, hard drive and power button stay on for 3 seconds or longer. When status lights remain on, remove your finger from power button and allow the machine to boot as usual. Enjoy.
Feb 19, 2011 | HP Compaq Presario F756NR Notebook
Toshiba Satellite P25-S5093 screen/boot problem
the memory cards are loose or are dirty and need the contacts cleaned with pencil eraser.
when the memory cards lose connection you lose video on screen.
Jun 18, 2010 | Toshiba Satellite P25-S5093 Notebook
Laptop boots up for 2 seconds and then goes to a black screen
just remove your ram if u can and wipe it with the clean cloth and insert it again so that the bios mite reset... or you have to change the jumper on the mother board which you have to take to an technician and get it done...
Jul 30, 2009 | IBM (92P6581) for ThinkPad T40 (92P6581)...
I have the same problem.
try turning laptop on without power lead in, seeing you have a new battery? hold power button on for 10 seconds to see if computer boots up on screen
Jul 01, 2009 | HP Pavilion dv6000z Notebook
Gateway 7320GZ Notebook Logo
379 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
