Question about GE Microwave Ovens
Load humming.(louder then normal.) - GE Microwave Ovens
  • iluvmyshort Jan 06, 2009
    It seems I have a similar problem. My GE makes a humming sound that kicks in about 2 seconds after turning it on to heat food up. Other than that it works perfectly. What could be the casue?
  • William Miller
    William Miller May 11, 2010
    Is it still heating?
    If not, I would say the high voltage rectifier diode is shorted.
    If it is still heating, you magnetron is going out.
    How old is it? What is the model number?
    GE's have a magnetron warranty of 5-9 years in most cases.
It does not heat.
I already replaced the HV diode. That did not fix the problem
It still has a loud hum and no heat. I'm guessing the magnetron.
The unit is six years old. I did not purchase it, the unit came with my house.
Model # JE1660MB002
Posted on Sep 25, 2008
My Neff microwave H5470NOG/03 has stopped heating food, any ideas?
It has a internal Dio fuse..You have to take cover off to see it.. Warning...High Voltage...There pretty cheap...
Oct 04, 2017 | Neff Microwave Ovens
My microwaving is humming
just about all microwaves hum-----the fan,turntable motors make a hum if louder than normal check that turntable it not stuck or off track
Sep 07, 2015 | GE Spacemaker JVM1640SJ Microwave Oven
KEY PAD SEEMS FINE BUT WHEN YOU HIT START UNIT MAKES LOUDER THAN NORMAL HUMMING NOISE AND UNIT DOESN'T HEAT ANYMORE
The magnetron has failed or the high voltage transformer is the problem, either way! it is very expensive to replace, cheaper to buy new.
Jan 13, 2011 | Tappan TMT104E1 Microwave Oven
When you start the microwave it starts normally with a low hum, then a couple of seconds into it the hum gets louder. After the cook time has expired the food is still frozen. Is there something I can do...
Replace the magnetron by the sounds of it. The hum gets louder a second or so into "Cooking", that would comply with the magnetron heaters coming on and working into a dead magnetron. It could be capacitor or diode of course.
Dec 27, 2010 | GE JVM1540SMSS Microwave Oven
Magnatron suddenly making more noise. Much louder
Often over the years the Transformer laminations can loosen, from the on/off rising and collapsing magnetic fields, and then they sorta hum louder. I suspect this is what is going on. Shouldn't be too much of a worry.. keep an eye on it tho.
Jan 20, 2010 | GE JVM2070 Microwave Oven
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
GE JVM1440BD Won't Heat
If it making a louder than normal humming or grunting sound when operating, than it's a sure bet it's the MAG.
Jun 09, 2008 | Microwave Ovens
GE Spacemaker XL 1800 Microwave It has a louder than normal humming noise and it isn't cooking anything.
The magnetron usually has a 5-9 yar warranty.
You might contact GE Customer Service at http://www.geappliances.com/service_and_support/contact/
Otherwise, what is the exact problem you're having?
Dec 07, 2007 | Microwave Ovens
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
113 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
