Question about HP Officejet J5780 All-In-One InkJet Printer
HP j5780 stopped print Black
Did you have a solution to this problem?
    Genius:
  • 1,689 Answers
This is the link to my answer to your question...
http://www.fixya.com/support/t1074229-stopped_printing_in_black_installed_new
Posted on Sep 24, 2008
5 Suggested Answers
sanjay_tech
  • 20 Answers
SOURCE: HP Officejet J5780 : copy's and scan's result : black page
Try to disconnect the power cable from the back of the unit and reconnect it after few secs. The alingment will start itself. Complete the alingment once.
Posted on Jan 26, 2009
marlen56
  • 110 Answers
SOURCE: My HP Officejet J5780 is frozen in delete
follow the steps below to resolve
goto http://www.hp.com/cgi-bin/hpsupport/index.pl
select country (select US you can the follow the steps below
exactly as given to reach the resolution)
select See support and troubleshooting information
enter your product name (in your case HP Officejet J5780) and click on >>
then select Solve a problem
select Printing
select Slow or no response from printer
select Print Jobs are Stuck in the Print Queue and Will Not Print with a USB Connected Printer in Windows Vista on this page you will find also the link for XP solution. Read the instructions and use utility to resolve the issue automatically. It will fix your problem !!! TIP register your product at HP support website and add the link to your Favorites. If you need more information, send a comment Success
Posted on Aug 30, 2009
  • 1126 Answers
SOURCE: HP OfficeJet J5780 Vertical Black Line Prints when
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Posted on Sep 07, 2009
adnanbhatti
  • 1188 Answers
SOURCE: HP Officejet J5780 now prints in mirror image. I
Go to printing preferences and change the mirror image option to off and then try printing again. Use this figure as a guide:
Posted on Sep 08, 2009
I just changed my black cartridge and the printing
Dip the bottom of the cartridge in some hot water. This should open the head so the ink can flow out freely. Once the ink is flowing into the water remove and dry the whole cartridge. Insert into printer and print.
Good Luck
Jul 20, 2010 | HP Officejet J5780 All-In-One InkJet...
Hello, My J5780 Has Just Atarted Printing
In printer properties and then in printing preferences, look for and turn off mirror image printing, it's there for printing transfers to shirts and things that you need reversed.
Dec 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Sep 08, 2009 | HP Officejet Pro L7680 All-In-One Printer
Uncleared print job HP J5780 I'm pulling my hair out trying to print to my HPJ5780. With a failed manual duplex job, I tried to delete the print job from the queue. It came up fine as deleting - however...
Try stopping the print spooler service and canelling all the documents.
The Windows Print Spooler is a Windows XP "Service". You can start/stop it via the following steps:
  1. Click on the Start button
  2. click on Run
  3. enter "services.msc" without the quotes and press Enter
  4. Scroll down to Print Spooler
  5. Single-Click on Print Spooler
  6. The details will open in the middle of the window.
    • It probably shows Start -- if so, Start it.
    • If it shows Stop and Restart, I suggest Stop it, then Start it.
Jul 16, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 All-In-One Won't print double sided with Vista
You can install an instance of the Deskjet 6500 series drivers using "Add Printer", local printer, (use the same port the J5780 is installed on). You can have this co-exist with the J5780 driver and you could name it J5780 Duplex if you wish.
Regards,
Bob Headrick, MIcrosoft MVP Printing/Imaging
Mar 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
Jan 26, 2009 | HP Officejet J5780 All-In-One InkJet...
well steve congratulations then...
if you have other questions just lemme us know and we will do out best to help out.
im looking forward to working with you again...
Sep 25, 2008 | HP Officejet J5780 All-In-One InkJet...
Stopped printing in black Installed new cartridge
Hi sapoteet, i actually sent a request for you:
about your issue on the printer not being able to print black, what have you done so far?
have you used another cartridge? or changed the software for your printer?
im willing to help out, just lemme know some more information about your printer.
Sep 24, 2008 | HP Officejet J5780 All-In-One InkJet...
Wont print
Don't need the help now. Please leave me alone. I solved it myself without your help.
Sep 10, 2008 | HP Officejet J5780 All-In-One InkJet...
Printing both side of the paper using HP Officejet J5780 All in One
Make sure that you have the duplexing option turned on in your printer configuration. The "OK" button is right below the window that shows the date and time. Have a look here:
http://h71016.www7.hp.com/html/interactive/j5780/model.html?jumpid=in_r2910_3d/PDI/j5780%7Cshowcase%7Cflash
Jun 12, 2008 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 All-In-One InkJet Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
