Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Upright Vacuum Cleaner Lost Suction
Replaced filters, dust bag and attached bounce sheet behind fliter sears part no. 20-86884, for good smell. It runs for a while then I heard a deep roars and the suctions stops. Is the motor dead or just the on/off swtich part no. 4368653 needs replacement. The protector springs is okay. Thanks. Ed Cruz
ecruz@sbcglobal.net
    Problem Solver:
  • 17 Answers
If you had the dryer sheet under the intake filter for any length of time you risk burning out the motor . If
it smells like burning hair and plastic then the motor is toast. Also check the hose and dust passage, but I fear that it is the motor.
Sorry...
Posted on Sep 24, 2008
Doesn't seem to have much suction when I put my hand under the head. Have cleaned both the filter and the mesh screen
Check the suction from the hose for rge tools see if there is suction
also check to see if there is a obstruction on the short hose to the nozzle
May 16, 2016 | Hoover U5140-900 Widepath Bagged Upright...
Changed filter and bag. no suction, dust comes out of the front of the vacuum covers the vacuum cleaner.
If it is an upright vacuum cleaner you need to turn it over and remove the base plate. There are usually 4 easy turn tabs, or 4 screws. Under there on one side behind the brush, you will see a hole where the dust goes up into the bag. Yours will be blocked. Often a piece of stick, a hair grip or something blocks the hole and then the fluff builds up on it until fully blocked.
Let me know how you get on by clicking the COMMENT button on this post.
Dec 01, 2015 | Filter Vacuums
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Since I replaced the bag in my Eureka Rally 2 (this was the first time) the suction has not been working well. Could you please tell me what I could have done incorrectly. Thankyou
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Mar 28, 2011 | Eureka Vacuums
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
Dec 25, 2010 | Eureka Vacuums
Hoover upright bagless vacum.motor runs, brush turns, no suction through hole behind brush roller. however there is suction going out of dust cannister filter flap to motor. what could possible problems...
Sorry to read about your problem, I hope this helps you out.
you have a clog between the brush and bag
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
Dust blowing out of the side of vacuum
make sure that the filter in the dirt cup is in place.
Dec 30, 2008 | Eureka Whirlwind Litespeed 5740 Bagless...
How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Jan 05, 2008 | Vacuums
My bissell vacuum cleaner has lost suction...
Sounds like either the hose or the inlet down by the brush roll is clogged.
Dec 15, 2007 | Bissell 3522 PowerForce Bagged Upright...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
198 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
