Question about Maytag Neptune MAH5500B Front Load Washer
Mildew buildup on rubber at door opening
There is quite a bit of mildew buildup on the rubber I see when I open my front load washer. How can i get it off?
  • 706 Answers
Hello mamie7,
You are not alone with your problem on your front load washing machine..seems they all suffer from this phenomenon. because in order to keep the water from leaking out the fornt door.. it has to be water tight.. and because it is water tight, it is also air tight so any water left in the gasket for any length of time will develop mold and get mildew there.. There are a few solutions ( no pun intended) floating around but I subscribe to a few basics.. One being .. wipe the gasket after a wash cycle and leave the door open to air dry any moisture that remains. The problem with this is that some housholds have small children and the washer then becomes a danger to them... So.. you can do a periodic wash cycle using a product called AFRESH ( in tablet form and sold at home depot etc) or you can try this product at http://www.smellywasher.com/ . Good luck.. hope this helps you..
Posted on Sep 24, 2008
How do I get the mold on the rubber at the front of the washer off?
You can try with some propriety mould and mildew products from a hardware store like wilkinsons.but rinse machine thoroughly before attempting a normal wash.It is very difficult to completely remove these stains if the machine is old.it is likely your machine is not rinsing properly due to overfilling with clothes.try putting less in and after use wipe inside rubber with cleaner and leave door slightly open to allow it to dry out after use.Try using calgon to remove calcium buildup if you live in hard water area as this can aid the buildup of mildew.if you have children then obviously you can't leave it open.
Nov 11, 2015 | Washing Machines
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Okay the rubber in the opening of the front load washer has black spots on it which is some kind of mildew or mold that makes the cloths smell mildewed after washed the spots wil not come off what is the...
    Front load washers need more maintenance than top load units. you might try some bleach on a rag or some vinegar but it's tough to get off once it starts..Make sure your using HE detergent and definitely leave the door open after loads to let the seal dry
    Sep 22, 2010 | Frigidaire GLTF530DS Front Load Washer
    I have a mildew smell within the washer and have
    Leave the door open all the time and it will dry out and the mold and smell will subside.
    Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Mildew smell
    PLEASE KKEP IN MIND THAT THE MAYTAG NEPRUNE FRONT LOAD WASHER IS WHAT GOT MAYTAG IN TROUBLE!!!!!!
    Whirlpool bought MAYTAG about 3 year ago.
    THe mold is because of the rubber boot in the front of the door. PLEASE check to see if the rubber seal has a small hole in the lower bottom of the seal to let small portions of water drain out. If you DO NOT have this small hole, you need to replace the rubber boot with one that has a hole.
    NOW, WORD TO THE WISE and this is what I tell ALL FOLKS that have a FRONTLOAD WASHING MACHINE:
    AFTER you washer in the washer LEAVE THE DOOR OPEN so that the washer can ventilate and remove any moisture that is within.
    ALSO, every 2 months, get a WHITE CLOTH with WARM WATER and a littl;e bit of BLEACH and CLEAN THE RUBBER BOOT!!!!!!
    Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Strong mildew smell in washer is making cloths & towels smell bad, how do you get rid of the problem?
    if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
    I use tilex sometimes and do a rinse spin.
    Nov 16, 2009 | Kenmore Elite 45986 Front Load Washer
    Mildew on rubber gasket around door.
    This happens when you keep the door shut. Run an empty load with extra chlorine bleach to kill the mold spores. Keep the door open to prevent mold or mildew from growing again.
    Mar 18, 2009 | LG WM-2277HW Front Load Washer
    Smell in Front Loading GE Washer GCVH6260F
    more likely due to using liquid detergent - change to powder
    Dec 01, 2008 | GE Energy Star WCVH6260F Front Load Washer
    GE front loader washer soap inside door
    You can try using soap powders for 'front loading' machines......
    Mar 03, 2008 | GE WSXH208A Front Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    156 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
