Volvo V40 Stall when foot off pedal and DSA light on
Volvo V40 seemed to need more time to start and stalls out when foot is off gas . Also the DSA light is on and trying to push the DSA switch doesn't make any change.
Re: Volvo V40 Stall when foot off pedal and DSA light on
Needs a throttle body cleanin--idle air motor maybe aging--get car scanned soon--mite also hav a vacuum leak--get a repair manual for troublshoot procedures
hi
1: yes it is the gear box
2: I am not sure, but I think yes 1998 gearbox will fit into 2000.
if you have the 1998 gearbox in front of you, then you can compare it
Have you cleaned the throttle valve and the idle speed control valve, how about the cleaning the fuel injectors? not a can of cleaner but a professional cleaning at the dealer? These three items can all cause your problem and as a pro tech it is where I would start. One more question have you checked the OBD 2 system for trouble codes?
If the car shakes and stalls at lights stop signs etc. I would check the egr ( exhaust recirculator valve) first this valve should open when in driving mode and close immediately when engine comes back to idle. to check this find the valve on the intake manifold ( looks like a mushroom) remove vaccuum line and plug hose drive the car and see if it fixes the problem. If it does get one from local parts store. Most brands such as standard are universal and come with baffles that must be installed. do not leave the valve disconnected the engine will "ping" when driving forcing you to buy higher octane gas. It is also illegal to remove this unit for emission reasons.
The DSA light did go off by it self for a short time and then came on again
