Question about Bosch SHU9925UC Built-in Dishwasher
Drainage problem my washer will not drain after wash
  • 706 Answers
Regardless of the brand dishwasher, they all have the same fundamental plumbing. so.. you need to check a few basic things first..
1. Have you cleaned the drain filter or screen?
2. Is the drain hose kinked or restricting water flow?
3. Is your dishwasher pump blocked internally or the hose entering or exiting it ?
4. Is the house drain ( meaning : where that hose drains water into) restricting water flow? ( back pressure or clogged?
Any one of these conditions will manifest itself as an undrained dishwasher.. Hope this gives you some things to check and you get your problem resolved...
Good Luck
Posted on Sep 24, 2008
Electrolux front load washer drain
Good Afternoon Friend,
I see that your Electrolux washer, model# EWFLS70JSS, is having trouble draining. First, I would start by checking the drain hose, to make sure there are no kinks in it and it is not clogged. Secondly, I would make sure that the drain hose is between 6-8 inches down inside the drainpipe. If it is too far inside the drainpipe, it can cause slow or no drainage. Thirdly, I would make sure that the drainpipe is not clogged. Finally, I suggest resetting your washer. You will do this by either unplugging it or shutting the power off at your homes circuit breaker for 2-3 minutes. When the power is restored, run a wash. If your washer is still experiencing a no drainage issue, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Apr 16, 2014 | Electrolux EWFLS70JSS Washer
Bosch Nexxt Premium Washing Machine Drainage Blocked. Cleaned out impeller still not working.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jul 02, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
The cycle washes and agitates but then a Err 20 shows up before the drain cycle. When i restart on the drain\spin cycle the machine starts again but no spinning happens
Drainage problem. If it is a new installation the possible causes can be:
- The drainage hose is too deep in the drain (can only be max. 10 cm. in the drain, and the drain height may be a minimum of 30cm and a maximum of 80cm from the floor);
The drainage pump may be blocked (clean it);
- The drain is clogged.
Mar 12, 2012 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer does not drain water
The major reason for this to happen is the clogging of the drain pipe of the washing machine. If, even after you clean the drainage hose, the problem persists, there may be other problems.
Next possibility could be that the drainage pump which drives the water out of the drainage hose may be clogged! So, remove the drainage pump and clean it. That should solve the problem. it might also be that the belt of the drainage pump motor may have loosened. If this is the case, you have to simply tighten it.
Take care.
May 30, 2010 | Whirlpool LSR5132PQ Top Load Washer
Agitates but wont drain
Take care
May 30, 2010 | Kenmore 22422 Top Load Washer
Drainage blocked
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
My machine is going through a wash cycle and has stopped with a "drainage blocked" light
Look for a kinked drain hose. Make sure drain hose is not plugged. Remove drain hose from washer and inspect drain outlet on washer is not plugged. Stick your finger inside and feel for any clothing fabric ect blocking drain line. The washer may have a built-in screen that is plugged. You may need to remove the back cover of the washer and inspect drain hoses for any kinks or blockages.
Sep 26, 2009 | Bosch WFMC 3200 Front Load Washer
Washing machine inlet/drain problem
You may have a simple problem known as "siphoning". Have you checked your installation/ In particular, the drain hose? the following link explains how to check and correct a siphoning problem with a washer:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Usually when a washer drains as it tries to fill, its a drainage problem of some type. You may have a simple problem that is easily remedied. You may not require anything, but pulling the drain hose up out of the standpipe and repositioning it to ensure there is a proper air gap for drainage. I hope this helps you.
Aug 14, 2008 | Washing Machines
Drain problem in GE WBSE2090A washer
hello, if you washer is not or isn't fully draining that sounds like something might be in the pump.Icheck for any hose blockage as well.If there is a bad smell that might be dirt or a peice of clothing or anything. so my suggestion is to check your drainage hose, the pump or maybe try even to syphan out the pump which means put the drainage hose in a bucket lower than the washer or your drainage is higher than the washer. good luck...
Jan 23, 2008 | GE WBSE2090A Top Load Washer
Bosch SHU9925UC Built-in Dishwasher Logo
265 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
