Question about Epson Stylus CX6600 All-In-One InkJet Printer
Build up of ink on rollers , how on earth do i clean this off as my print outs are all grubby mucky looking cheers
  • Anonymous Feb 18, 2009
    smudges of black ink on the edge of the paper, I'll try and copy ten sheets of blank paper??
    Scholar:
  • 94 Answers
Hi, please attempt running several sheets of blank plain paper or try to copy a plain blank paper for 5 to 10 times.
Posted on Sep 30, 2008
How do I fix HP LaserJet P1606dn printing issue? it continues to print vertical line/ smudge on the far left of the printed document. Does anyone have any suggestion regarding this issue?
The smudges on the side of the paper is most likely a piece of something rubbing against the paper just after the printer puts the ink on the paper. Inspect as much as possible the path that paper takes. Look at rollers. Anything that grab the paper. Look for ink and dust build up. As for the vertical lines. Could be several things. I you haven't used you printer for awhile the ink in the nozzle could of dried up. Most new printers have a nozzle cleaning function. Try that it a couple of times. See if that helps. If it shows any sign of change after that, it dried up ink. It's a hassle to try to get the ink flowing again. I normally just to replace the cartridges. Let me know if this helps or not.
Aug 05, 2015 | HP LaserJet Pro P1606DN Laser Printer with...
The black cartridge leaves blank lines while printing
This usually really means that you have clogged ink inside the delivery tube for the black ink flow to the inkjets. VERY Hard to repair, but since you still have ink flowing, switch to blk ink printing such as lots of text, and keep printing it out to see if it will clear out the dried ink in the micro tips. You can't change out the printer roller in this unit. I know, that frustrates me too! This may take a bit of time to do!! Also make sure your printer blk is up to date with new computer 'read' tabs, if not it can create read problems in the system. If you refill inks at a store, which of course is cheaper, make sure they also install the reader tab on the ink block.
Hope this helps!
Cheers
Vicki
Mar 04, 2013 | HP Photosmart C8180 InkJet Printer
Ink streaks
Ink streaks are usually caused by a buildup of died in on the print heads. There are two print heads in that unit. Remove one at a time and look for build up - clean it if you find any. Once you finish cleaning both print heads you will need to do a print head cleaning routine in the HP software to clear out any in clogging the print nozzles.
Oct 01, 2012 | HP Officejet 6500 Wireless All-in-One...
Printing is coming out blurred.
Hi james966, if you are printing a photo, try and printing it in asmaller so it won't be blurred. I hope i helped you! If you likedme please rate!
Jun 08, 2011 | Office Equipment & Supplies
I have an Epson Stylus Photo R260 inkjet Printer that is printing fine except the black ink is leaking all over the page or CD/DVD that I print. I have done numorous head cleanings, and it still is all...
I found this on fixya per dgsturt
It looks like you've managed to get ink all over the shop by using the self clean option. That't mainly to clear bocked print heads and tends to squirt a load of ink through.
That ink has to go somewhere, it looks like you may have some on your rollers.
First, I'd have a look through the printer menu see if there's a roller cleaning option, give that a go.
Second, I'm not sure but worth a try, try printing a document that has wording all down the page but use an empty cartridge. If your printer will do this you’re effectively using a sheet of paper as a mop to clean the rollers.
Third, probably the most difficult, get some Isoproprial Alcohol from the chemist and try and clean the rollers and print bed yourself with a lint free cloth and cotton buds, what ever works.
If you don't like the idea of Isoproprial Alcohol, it is highly infamable, try with a damp cloth first, but it will take longer to dry off.
If you find this helpful, pls rate me.
Thanks.....
Mar 21, 2010 | Epson Stylus Photo R260 InkJet Printer
Ink comes out heavy in spots on print outs as if you had a jam and then the ink smudges - ink does not smudge just heavy on certain spots
Sounds like you need to replace either the fuser or the rollers the rollers could have ink build on them and it would smudge the ink.
Oct 21, 2009 | HP LaserJet 6p Printer
Ink marks on paper
seems that the Print roller needs a cleaning. get it cleaned as there might be some extra ink on the roller.
Hope this Help.
Cheers!!!
Jul 16, 2009 | Lexmark E330 Laser Printer
Splotching and spotting ink
The roller cleaning will require you to remove cover to clean the full roller with alcohol to remove ink build up. Have you tried to just run/feed a blank piece of paper through to see if you have roller ink roll off?
This also sounds like a bad cartridge with clogged jets...
Jun 15, 2009 | Canon i80 InkJet Printer
When the printer starts to print, one line gets printed- then the paper sticks. The printer says "Clear the Carrier Stall". what does that mean?
Paper Jam...try to clean your printer, get a can of dust off (compressed air) and blow it out. Then take a damp (unplug printer first) and clean the paper rollers. Keep an eye out for anything sticking to the rollers, ink mist build up, or sticker from labels, or just glue from stickers.
Hope this helps you, please leave a rating.
May 05, 2009 | Computers & Internet
Print head error? (13.004.43)
The Printer's Front Panel Displays Printer Error - Contact Service; Report Fault 13,004.43 Cause:
The left jet stack heater is not heating at all, or is heating too slowly TRY FIRST (Solutions without parts): 1. Poor ventilation. - Make sure printer has 6 inches minimum of clearance on all sides. 2. reseat the cables to the printhead. TROUBLESHOOTING TIPS AND HINTS: 1. added drum maintenance parts for damage control. replace as needed if worn or broken. PARTS:Parts are listed in the order of highest probability for repair. NUMBER QTY DESCRIPTION PROBABILITY% MODEL S/N FROM S/N TO S/N 650411200 1 *PRINT HEAD ASSY; . 367051501 2 FOLLOWER,CAM; DM CAM,SAFETY CONTROLLED, QTY 1 650428800 1 FRU, CLUTCH/ANTI-ROTATION COLLAR 351105301 1 GUIDE; DRAWER ASSY,DM RIGHT 351105102 1 GUIDE ASSEMBLY; DM DRAWER,LEFT,SAFETY CONTROLLED REPAIR/INSPECT/PREVENT PROCEDURE: 1. Clean pick rollers only when ink or debris is visible. 2. Clean feed rollers, exit rollers and guides only when ink or debris is visible. 3. Inspect cap/wipe/purge gasket and wiper blade. 4. Check for cooked or discolored inks; if necessary, flush out ink. 5. Inspect and clean the drum maintenance blade and the rapid release guide. Check print quality; if necessary, perform clean for light stripes. 6. Check cleanliness of interior and exterior of printer, including fans; if necessary, clean (dust or vacuum) these areas. 7. Report the use of Non-Tektronix/Xerox ink. 8. Review proper operation of printer.
Mar 18, 2008 | Xerox 8200/DP Thermal Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
