Question about Samsung SPN4235 42 in. Plasma HDTV
Samsung HDMI issue
My 2006 Samsung 50 inch plasma tv's HDMI ports (1&2) stopped working. When you turn on the cable box or the DVD player, there is a picture and sound for aprox. 5 Sec. then the screen turns bright green and it's just sound. If I hook up the componant cables it works fine (just not a clear as HDMI). Any sugestions?
  • retcpd Sep 25, 2008
    Similiar problem with my 46 in Samsung DLP not reading my DVI connection. Had to use compnent cables.
  • Anonymous Mar 30, 2014
    My samsung tv flickers off and on when I use the HDMI cable
    Scholar:
  • 93 Answers
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Posted on Nov 06, 2008
  • Michael Ackerman Sep 13, 2013
    already changed the caps on the power supply. now i have this hdmi problem. i use the cable for testing its fine
How to get video from dvd to tv
Use HDMI wire if you have that option than simply tune TV to HDMI 1 or HDMI 2 etc depending which one you connect it to .
OR. analog ( R C A ) cables analog. Output from DVD player to imput tv """ red is right white. Is left sound. Yellow is video pay attention to where you are plugging on TV.video 1 or 2 or 3 Since you will have to go to ( video. Or imput ) on your TV to access the DVD player. Another words your cable box is a TV imput . You're doing is also a TV imput You have to tune it to be able to watch it
Feb 16, 2015 | Universal 40-42 Inch Flat Screen Panel...
I have a beko 37 inch hd ready tv i recently go the sky hd box . my tv only has one hdmi port and i also have a samsung blu ray dvd player which only has a hdmi connection i got a switcher box for the hdmi...
It is possible the hdmi cable that you are using is faulty. The reason I say this is because you have multiple signals that pass through a hdmi cable (19 pins in it means 19 wires to carry signals). The more the cable gets moved and bent, you increase the chances of creating a short or re-connecting a short if moved from one tv to another. This is the best case scenario as it is easier to replace the cable and less costly. Since you already connected the the dvd directly to the tv, and I am presuming that you have working devices running through the switch and you can eliminate that as the problem. If you do not have working devices on your switch or directly into your tv, and you have tried multiple hdmi cable and still nothing, the hdmi connector on your tv is probably bad and that would be the worse case scenario.
Nov 03, 2013 | Philips Televison & Video
HDCP AUTHORIZATION FAILURE- HDMI PORT DISABLED
i just had it happen half hr ago and pulled power cable out of box for few seconds and plugged it back in...turned it on and it basically reset itself works great now
Apr 15, 2012 | Televison & Video
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Hooked up cable box, wii box and dvd player to new lg 50 inch 720p plasma tv... all external components work, however, dvds and wii only show in black and white - no color...
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Dec 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
TV does not always recognize the DVD player
that's a firmware problem where your tv's firmware does not handshake with your dvd's firmware. This could be from your dvd's software being to old for your tv to understand it. HDMI (TDMS Technology) still has Alot of catching up too do with 3rd generation tv's. Alot of HDMI devices still have the first gen software loaded into them. So a tv after 2005 won't work with HDMI from 2003 (1st gen). Most tv's made after 2007 have software that's "backward compatible" so they will work with first gen HDMI.
How does your tv perform outside this problem???
Feb 10, 2009 | Samsung PN50A550 50 in. Plasma TV
I have connected my DVD/VCR to my Samsung 32 inc television but I get no sound
I had a strange issue yesterday too.
Our Samsung DVD/VCr all in one combo did a similar thing.
I used the HDMI cable for the DVD into the TV input labeled HDMI/DVD. That worked okay.
But the VCR part didn't work.
At one point I got sound but no picture. Using the RCA cables in the back on another input "Component 1"
I was trying to squeeze the best picture out of the player using the S-VHS cable.
I thought it did picture only, but the Plasma seems to be more picky about input sources.
I got everything to work keeping the DVD as a separate HDMI to Plasma TV feed.
The VCR was 3 RCA's Yellow (picture) red and white for stereo sound.
I then reset (toggled through the inputs to "reset" the TV.
It finally worked but I was two days mulling it over.
See if this works for you.
My TV was a Panasonic Plasma, but shouldn't matter.
Skip the S-VHS line and connect the inoputs with the TV off.
You MAy need to go into the input of set up menu on the TV (ours had a wrench as an icon) and set the Component 1 or 2 to "VCR".
Aug 04, 2008 | Samsung Televison & Video
UPCONVERT DVD PLAYER HDMI PROBLEM
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Jun 06, 2008 | Televison & Video
HDMI f/ dvd, dvr, receiver and tv
best set up if you have all hdmi is to have all your components go into the receiver ie. hd cable box, dvd etc. by using the hdmi output from the player(s) to the hdmi input to the receiver. next use one hdmi cable from the receiver to the tv then your laughing.
good luck
smeags
Dec 31, 2007 | Onkyo TX-SR605 Receiver
Samsung SPN4235 42 in. Plasma HDTV Logo
857 people viewed this question
Henry  Thomas
Henry Thomas
