Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi wd 52825 dlp
Had lamp failure. I replaced lamp, tv started up--no picture. Ran for a short period 2-3 minutes, then cut off, with lamp indicator light red. what's the problem and can i fix it or is service required? thanks for your help.
  • waveware Mar 07, 2009
    To Tim Nolan or anyone who is able to assist me
    I have a Mitsubishi WD-52825 with lamp light solid red. I have replaced
    with a new bulb and when tv is turned on, the red light came back on
    after 2-3 min. I've checked and rechecked all the connection of the
    lamp housing and don't believe there is anything wrong.
    If it is a problem with the capacitors on the power supply board, could
    you please kindly walk me through it? I do have a multimeter and know
    how to use solder.
    FYI, I've spent more than $1,500 on this unit last year to fix various
    problems including replacing entire power supply board. I really can't
    spent anymore on it and would greatly appreciate any help/assistance
    you could extend.
    Thanks in advance,
    Wilson
    email: waveware@yahoo.com
    Novelist:
    Champion:
  • 203 Answers
Most commonly this is caused by a faulty power supply, more specifically 2 capacitors in the power supply. If you know how to use a meter and solder let me know and i will walk you through the repair. Otherwise service is needed and the repair should runn you $300-$500 depending on your area.
Now that i type that i did remember one more thing that can cause this. I would take the lamp out and look to make sure the connectors that it plugs into are not broken, sometimes when a new lamp goes in it doesnt line up right and brake the connectors.
Let me know!
Tim nolan
experttv@comcast.net
Posted on Sep 24, 2008
Green blinking light on Mitsubishi DLP 52825
Hello, unplug the tv and check the lamp to see if it is broken inside. here's a link on how to replace the lamp.....tks.... https://www.youtube.com/watch?v=3bQ0wut_pWg
Jan 26, 2015 | Mitsubishi Televison & Video
No picture
If you are not using the correct bulb, that is exactly your problem. Get the correct lamp.
Mar 15, 2013 | Mitsubishi 915p020010 Wd-62825g / We-52825...
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Jul 17, 2012 | Mitsubishi WD-60735 Projection Television
Posted a short while ago but have more information Mitsubishi DLP WD 52725 - sound no picture - blinks 3 short times and 1 long time
have you checked the lamp? with those models they will power up and if the lamp is bad you can hear audio until the tv shuts off. the lamp is located in the front behind the speaker grill assembly. if the "status" light is blinking then you are having a fan failure if the "lamp" light is on then check the lamp like i listed above.
Jan 06, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Oct 30, 2009 | Mitsubishi WD-52825 52" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Replaced lamp in WD-52825 but still no picture. Lamp indicator on.
the DM board has gone bad. it is not the 4 100uf caps on the board. it is surface mount parts. it this board has failed then the FMT board is not far behind. the chassis needs to be rebuilt. www.tv-techs.com
Aug 29, 2008 | Mitsubishi WD-52825 52" Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
147 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
