Motorola HDT101 DTV Receiver Logo
A
Anonymous Posted on Oct 30, 2011
My dsr530 star choice wont record and has lost all my pvr recorded problems
3 Related Answers
Anonymous
  • 8 Answers
  • Posted on Jan 20, 2009
SOURCE: instructions on how to use a dsr530
here you can get it:
http://www.starchoice.com/english/store/download/DVR530hd_manual_e.pdf
Anonymous
  • 374 Answers
  • Posted on Dec 31, 2008
SOURCE: can I record antenaTV on my Dish PVR-625
Officially, no you would not be able to since you no longer pay the $5.98 DVR fee which Dish charges for the DVR. Wish I could have given you better news. Thanks for using Fix Ya and let me know if I can further assist you.
Anonymous
  • 358 Answers
  • Posted on Feb 16, 2011
SOURCE: zero audio no matter what I've tried. It worked
susan_basske
I would check your cable between the receiver and TV to make sure they are secure at both ends. If this doesn't work, try unplugging the receiver from the electrical outlet for about 10 seconds. I hope this helps.
Ray Calo
DISH Network
Where do I get a digital tuner and how do I attach it?
There are many choices these days, but the digital tuner box would normally come from the company that supplies your cable signal. The digital tuner usually includes a PVR (personal video recorder). As long as you television is modern, connection will be via an HDMI Cable which comes with the box.
https://www.google.com/search?q=television+digital+tuner
https://www.google.com/search?q=hdmi+cable
These are like mine and come via a super fast internet telephone line.
bell fibe pvr in Canada
Kijiji https://www.kijiji.ca > b-canada > bell-fibe-pvr
Bell Fibe TV VIP2262 HD PVR Cable Box 1TB. $30.00. Bell Fibe TV VIP2262 HD PVR Cable Box 1TB.
1helpful
How do we pre program our Rogers PVR so we can record new episodes of our favorite shows without haveing to program on a daily basis
You cannot program the PVR to only record the new episodes with this unit. However, you can set it to record all episodes of a program. Press the Rec button on the remote. Select your PVR that you want to have record the program. Use the arrow keys to navigate to More Recording Options. Select All Options. (Note: if your program is moved by the channel programmers, the show that airs instead will be recorded by the PVR.) This is shown here: https://connected.rogers.com/how-tos/posts/get-connected-with-rogers-whole-home-pvr-626435 .
I hope this helps.
(I've set my DVR to do this for only a financial news show that doesn't have repeats.)
How can we record movies directly from tv?
You can record movies on a PVR from cable and I'm sure that there are devices that can record over-the-air signals as well. The problem with cable is that the signal is encrypted and it is not easily recorded, thus the need for a PVR. I have recorded movies to my computer after attaching the over-the-air cable to TV Tuner, either a card inside your computer or via USB.
Good luck,
Paul
Bauhn Manual for APVR-9650T
http://forums.whirlpool.net.au/archive/2211037
Quoting from above:
Bauhn 1TB PVR
model APVR-9650T
a REVIEW
Spent a couple of hours with this PVR, comparing it with an earlier model Bauhn 1TB PVR (AS-PVR1000R, 2011).
Bought on sale Wednesday, $199.
[Only commented on differences between models. Have previously reviewed the older model - which still is a reasonably good PVR.]
Summary: not bad, some good features in a budget PVR, and a couple of annoying issues that weren't in older models (which should be easy to fix in firmware). Works well, responsive remote, although I prefer the button press of earlier model.
But product quality control is worryingly patchy. Bought 2 units, 1 was dead out of box!! Confirms my advice to buy 2 to get 1 that works well. (On power up with good broadcast signal, TV displayed Bauhn logo for few seconds, then blank screen, sound of HDD, and never advanced past "----" on PVR. Tried many times on different video outputs & TVs.)
I'll probably be returning this PVR within 60 days as the few annoying aspects outweigh the added features for my needs, over my older BAUHN PVR.
Features:
Series Record:
Records all programs with that title on that network. (Still assessing if SERIES RECORDs program on more than 1 network - e.g. records Simpsons on 10 & 11, but does it SERIES RECORD Mythbusters on SBS, as well as 7Mate?)
Good if you are away from PVR as it changes recording times to latest EPG (as long as broadcast sticks to EPG times), if program schedule frequently changes, and does not record if program is dropped from schedule.
(I have returned from overseas to find what I had set to record was not what was recorded as the program line-up had changed. SERIES RECORD should solve that.)
But... takes up many available recording schedules including ones you may not want recorded (PVR has maximum of 50 TIMER schedules, so for example SERIES RECORD "QI" on ABC1 - with 13 episodes/wk, would occupy over ¼ of available schedules!).
Also you cannot pad these recordings - adding a few minutes before/ after in case program starts early/ ends late. Changed recording time may conflict with other recording schedules meaning program may not record (check by EPG Search). Takes some getting used to to ensure consistent recordings.
Setting up standard weekly etc TIMERS may be preferable & more predictable.
EPG Search:
Searches for all programs by title within 7 day EPG, on all channels. Shows & allows setup of recording schedule, and if there are conflicts between SERIES RECORD & recordings, to set Priority.
Scheduled Recordings from EPG:
Settings for recording Once, Daily, Weekly, Weekday/ Weekend.
You can pad scheduled EPG recording times by up to only 10 minutes, in case program airs early/late.
(The older 1000 model can pad up to many hours - e.g. to record multiple consecutive shows on 1 recording, and the recording date can be changed to skip that particular recording. You can manually set up recordings to achieve this on this PVR, but then lacks program name, which you can rename. An advantage if you are running out of schedule recording slots.)
Time Shift:
Up to 2 hours, which is adequate. Can set to always be on, so can pause/rewind live programs when you wish. (1000 model can be set to almost limitless Time Shift. Mine is set to 4 hours.)
Editing Recordings:
Editing would suggest removing unwanted sections, but this PVR simply marks sections of the recording for viewing, skipping the unwanted. The file remains the same size, and copying the file to another device leaves the original unedited recording.
Settings:
MENU-PVR Settings: (handy when setting up)
Set Time Shift length (30-120 min) + Time Shift Function (Disable / Enable)
Playback Start Position (Beginning of program / Continuing from where you were watching) Continuing is handy.
Auto Play Next Program (Disable - stops playing at end at end of recording / Enable to watch recording then next recording )
MENU-Settings:
Audio&Video Output Settings
(set to suit your TV etc)
Time (by State & Daylight Saving - otherwise EPG & recording time will be incorrect)
Channel List (press OK during live TV):
Can delete unwanted channels (which the 1000 model annoying could not).
Can set up 1 set of Favourite channels
External USB Storage:
2 USB (1 front, 1 rear) capable of accessing larger HDD (tried with 3TB) formatted as NTFS or FAT32. So quite useful, as I found on 1000 model.
Copying is painfully slow. On 1000 model, crashes occurred when storage for recordings was set to a USB device (MENU-PVR-PVR Setting-Recording Storage) - don't do it!
USB drives less than 16GB can't be formatted on PVR.
WARNING: If PVR freezes (too high load on processor like copying too much or Copying + Recording) while writing to external HDD, HDD may be corrupted when you are forced to unplug PVR from power! (Have had Seagate HDD totally corrupted twice with 1000 model - files cannot be recovered due to storage method). Best not to copy too much at time to HDD!
Networking: (Not assessed yet)
Via Ethernet cable. Can access recordings, photos, music on PC, and transfer to PC from PVR. Access is typically MUCH faster than to USB storage. But requires files to be in set folder, which may be unsuitable.
Media Player (Not assessed yet)
Photo & Music Players have been added . Playing MP4 files is not great.
Annoying aspects...
OSD can't be hidden when using Pause
Pausing live program, or recording leaves an information box on screen - there is no way to remove it. Pausing a recording is something I regularly do, to view details. The PAUSE bar includes the EDITING tools, making it larger than normal. As the on-screen-display covers nearly 20% of the screen, at the bottom, subtitles and information bars broadcast with the program can't be seen! You can only increase the Transparency, meaning you can see through the OSD (MENU-Settings-PVR Setting 1-60%). However, setting a high level of Transparency makes using any OSD difficult.
Slow boot time
It takes about 35 seconds to.power up from Standby to fully operational. While that is marginally faster than the older 1000 model, it is slow.
Slow navigation within EPG, Timer & Media Browser etc
There are no P+/P- (Page up/down) buttons as on 1000 model. Moving up/down a list to select between possibly hundreds of programs (recordings) is SO slow - moving 1 at a time instead of a page at a time. (Strangely the P+/P- can still be found in the onscreen keyboard when you Rename recordings or do an EPG Search. There it performs a keyboard shift function.)
Slow navigation within Recordings & Time Shift TV
FF/REW speed is a maximum of 32X, against 64X on 1000 model.
There is a very handy undocumented feature of FF/REW by holding down the right/left arrows - located around the circular OK button (while watching your time position on the progress bar). Handy for moving quickly to position in program or skipping ads. (I found this on the earlier 500 & 1000 models.) However it is SO much slower to FF/REW on this model.
Bright Standby light
As in the older model, the very bright blue light can be annoying, but easily fixed with a small piece of black electrical tape or similar.
PVRs take time to discover their flaws & features, so I'll keep exploring ;-)
Aug 10, 2013 • Cell Phones
2helpful
I have retuned my PVR 6200t recorder and have lost ITV and Channel 5 and several other channels. Any advice?
The Sagem PVR 6280 is specifically listed as a model which will have problems with the retune. Although the Sagem PVR 6200 and 6200t are not specifically listed as problem models they are very closely related to the 6280/6240 models and share most of the same firmware and software.
See the address below for a chart of affected models, you'll need to contact Sagem directly on 0845 0900 316 for either an over the air update or an update DVD depending upon the manufacturer.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
Sorry I can't provide you with a definite solution but it's very likely that your model is one of those which only Sagem can sort out.
Please return the favour by rating my answer.
1helpful
Instructions on how to use a dsr530
2answers
Connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Can I record from the hard drive of a pvr
YES.
Connect the PVR to the DVD recorder via scart or RCA phono connection.
Select the relevant input on the recorder, press play on the PVR and record on the recorder.
Top Motorola Televison & Video Experts
Bob C
Level 1 Expert
NOEL
NOEL
vince
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
