Question about Motorola Mobility RAZR V3
Signal is lost when sending txts and calls
So I've been having this problem on and off with my Razr V3m, Verizon provider. Randomly I will be trying to send a text or call and the signal will go to no bars and it will just sit there 'sending' the text/call but ultimately it will fail or just not do anything. Once it happens the signal really never comes back, and it isn't like I don't have reception, because I know that I should. The only way I've been able to get my signal back and the ability to call/text is by taking the battery out for a little bit, putting it back, and turning it back on. Sometimes the first time will do it, but others I have to take the battery out multiple times (like 5-10 times) and keep trying to get the call/text through. Its really irritating because it always seems to happen when a quick response is needed. I have tried the Master reset or clear, whichever one doesn't erase your contacts and it didn't help at all. Any other suggestions? Thank you very much!
  • mrbeewer Sep 24, 2008
    Actually, it has done the same thing while on the charger, so that shouldn't be it, but I will clean the terminals anyway :P I just tried calling star 228, but it keeps telling me that 'activation failed' I will keep trying it however, maybe it will make it through.
    any other thoughts?
  • mrbeewer Sep 25, 2008
    Hello again,
    I just tried the star 228 once more. I checking out what the preferred roaming list is and this and that, and saw that I should pick choice '2'. I didn't hear it ask, but I pressed '2' anyway and it did the update. So we'll see if it works! I hope so. Thank you again for the help!
This could be a problem of a weak or worn out battery. perhaps, the next time the problem persists, you could use the phones charger while making a text/call. another option is to check the battery terminals for dirt or other contaminants and clean accordingly. also, have you tried updating the PRL? this refers to the preferred roaming list. dont know why its called that, but it may update the software of the phone. do this by calling star 228, that is, the star button, then 228, then send. I worked in a verizon call center years ago and this is how the phone software was updated. good luck
Posted on Sep 24, 2008
My inbox on my razor phone says no messages but memory full
I mentioned this in another area. We just got my son a motorola razr v3m, verizon. Any time he tried to check his inbox (which is text) or tried to send a text it would show memory full....this was the same if he tried to take a picture and send it.
First take out your battery, with the battery out, hold down you on button for like 15 seconds to drain the phone of juice, then put your battery back in it and turn it on. If this did not reset your phone, and if you are on verizon as your carrier, then you need to call them and make sure that they have you set up on their text messaging program. It used to be that if you didn't have, then they would charge you .20 cents a text, but with some of the razr, such as the v3m, you have to actually be on a monthly text plan to view inbox, send text, send pics, and receive pics and texts.
Nov 03, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Bars disappear, can't call out
Seems like you have a bad transmitter and reciever. Send in for repair or get another phone.
Jul 25, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
My phone won't send/receive calls or txts. NO SERVICE
what you need to tell the service provider is that to delete the vLR on they network then add it again
Jun 01, 2009 | Verizon Communications Samsung Alias Cell...
Can't text on phone say memory full on razr v3m deleted every thing turn it on amd off and still wont work
Go to ur message settings. All txts and go to Auto Erase. Make sure its on. Should work after that. Thats what they did to mine at Verizon.
Aug 07, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorolla br50
This is an issue with the switch/routing system with your carrier and they are the only people that can correct it. Call *611 and speak with tech support, this is easily resolved. Dont settle for less than resolved when you call them. Call from a phone other than that cell.
Jun 06, 2008 | Motorola Mobility RAZR V3m Cellular Phone
RAZR V3m texting problem
u sould contact your service provoder for that matter cause the dropp thing has nothing with text messages
Apr 23, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razer V3M Won't start
It may be a software problem. Similar thing happened to my LG Chocolate from Verizon. I found out that certain Verizon stores can perform an update on certain phones. Maybe Sprint has a similar software update. You can call your service provider and ask.
Dec 09, 2007 | Motorola Mobility RAZR V3m Cellular Phone
I cant use blutooth to transfer files to other mobiles
My friend, Verizon is the worst company that makes bluetooth useless, The reason why this is? is because Verizon has its V cast music going, so they disable verizon phones to be able to transfer music or pictures phone to phone via blue tooth, this sucks i know, i dont think u can even put music using motorola phone tools as verizon phones has a totally different interface,
Dec 05, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Verizon Razr freezes
emptied your text messages lately? this used to be a problem with the old v3c and verizon.
Aug 22, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3 Logo
73 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
