Question about HP Office Equipment & Supplies
I have an HP officejet 5510 All in One and need to know if I can set up the fax machine with the existing cable phone line I have at home now
    Genius:
  • 2,120 Answers
Yes, if it's not a DSL or digital phone line. Plug the phone cord into the LINE port of the fax machine.
Posted on Sep 25, 2008
5510 all in one, my fax has stopped working. I reinstalled the 5510, the wizard set up my fax, it rings, picks up, BUT doesn't do anything else. Try to send and it sounds like it doesn't dial out? It...
First, I would suggest suggest you reset the FAX. If resetting does not solve the problem, you can then read and follow instructions on this link; http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669298&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=311255
1. Remove all of the paper loaded in the main input tray.
2. Press the power button to turn off the HP fax product.
3. Disconnect the USB cable from the back of the HP fax product.
4. Disconnect the power cord from the back of the HP fax product and from the electrical
outlet, and then wait one minute.
5. Reconnect the power cord to the electrical outlet.
6. Reconnect the power cord to the back of the HP fax product.
7. Press the power button to turn on the HP fax product.
8. Reconnect the USB cable to the back of the HP fax product.
9. Replace the paper in the main input tray.
10. Use the HP Fax Test Service to try to send and receive a fax.
Good luck.
Mar 24, 2011 | HP Officejet 5510 All-In-One Thermal...
I want to know how i can use my copy machine to a fax so i can use it for incoming or outgoing?
Install software
Make sure all cables plugged: phone cable, USB cable to computer
Send fax from computer:
- print your document to printer HP .... FAX
Send "traditional" fax:
- put your document into scanner input
- type phone number on HP Officejet keyboard
- push button "Send"
If your HP Officejet if connected to phone line, it reseiving faxes automatically.
Hope this helps
Nov 12, 2010 | HP Officejet 4215v All-in-One Printer
I can send a fax but can't receive a fax.
Hey. Try to plug only your line in the fax machine. Test if you can received. There may be a conflict between these machine.
Jan 30, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 5510 fax issues
Have you run through the setup procedure detailed in the User Manual? Unfortunately it is far too large to post here. Can you receive faxes OK? If you don’t know just dial your fax number from any phone and see if it answers and you can hear fax garbage noise down the phone. If so then that is a positive sign. If you get stuck then drop me an email to kw7157@yahoo.co.uk and I can email you a full check and test procedure for this model.
Jul 16, 2009 | HP Officejet 5510 All-In-One Thermal...
Machine shows "phone off hook"
Hi there
check where your phone cale goes into the machine you will proberbly find two sockets one marked phone and one marked line the phone line needs to go into the one marked line and a phone handset in the one marked phone if this is correct try ringing yor line that the fax is plugged into see if you get a ring or engaged tone if you are getting engaged unplug the fax and try again if this now works the chance is that the modem board in your fax has failed and will require replaceing
Regards AL "alstech"
May 18, 2009 | HP Officejet 5510 All-In-One Thermal...
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
Home phone line and fax on one line
Mine is free from Bellsouth. I do not know about other phone companies.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't fax long distance now-
Do you have a DIGITAL phone service like Vonage?
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line..
Dec 17, 2008 | HP Officejet 5510 All-In-One Thermal...
HP 5510 Faxing problem
hello jeremy
some guides and help from there site here see if this will help you .
riz.
Feb 22, 2008 | HP Officejet 5510 All-In-One Thermal...
Seeker5211
Seeker5211
