Every few hours I am loosing connection with the internet. I retart my pc and everything works fine unil I loose connection again and I have to restart again.. How can I find out what is the problem, the wireless card, my pc or the oparating system ?
    Genius:
  • 1,124 Answers
Seems to be your wireless card, probably is not on range or has some signal interference.
Posted on Sep 24, 2008
2014 Jeep Patriot radio will work and then suddenly stop. Bang on dash then starts again. Pulled out radio. Everything looked fine. Ideas?
Check fuse, may be loose, or ground wire is loose, plug connector, something is loose if you can hit it and if comes back on. Could be PC board IC chip solder connection, another common problem with electronics these days in vehicles.
Good luck, FREE-PPV
Dec 11, 2016 | Jeep Cars & Trucks
2000 silverado,runs good ,but sometimes wont start,lights,radio ect,work,however theres nothing to the starter,if you wait a few hours it starts fine.i brought it to the garage and they replaced the...
You either have a loose connection at the starter, or loose battery terminal.
You'd be surprised how many calls I got about your problem, and all it was, was a loose battery terminal.
Also, tap on the started itself...or the starter relay (under-hood, driver's side...in Electrical Center Box.)
Good-luck.
p.s. there is no sensor or reset for starter
Nov 17, 2009 | 2000 Chevrolet Silverado
2001 Suburban electrical. 100k. Intermittant elec. power?
it may sound like you have a faulty batterie. it could be a short cut inside it that come and goes. Try another battry. Good luck!
Aug 29, 2009 | 2001 Chevrolet Suburban
Pc does not boot after power on
Try taking out the RAM and putting it back in. Sometimes RAM can have a loose connection which causes intermittent issues. Also check your monitor cable connection on the PC and the monitor to make sure you're not just loosing video connection.
Aug 19, 2009 | Computers & Internet
Microsoft Wireless Optical Mouse 2000 - Laser Stays the Same
check the battery is secure in position you might have knock it loose when you dropped it
Jun 02, 2017 | Microsoft Wireless Optical Mouse...
Every day the computer stops for about half minute then come back again says at the bottom local connection now connected and usually occurs after switching on after half hour then so okmodel dsl504t ...
Are you saying your computer stops responding while you are on the internet? If you loose your local connection to your network, you loose your connection to the internet. Do you have a wireless connection?
Oct 31, 2008 | Computers & Internet
EOC-3220ext Loosing its wired connection with lan
Try to Flush DNS Cache
ipconfig /flushDNS
Also
May 08, 2008 | EnGenius EOC-3220 (EOC3220)
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
D-link 524 looses conection
check the timeout when idle settings on the router. you need to set it to 0 for never break the connection.
other options are to upgrade the firmware of the router.
you should also isolate the problem by connecting the pc directly to the modem to make sure the same problem doesnt occur. if it does then contact your isp.
good luck
smeags.
Dec 31, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
