Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso washer tub shakes and rattles
I have a Whirlpool Calypso washer that is giving me major headaches. The tub itself starts to shake rather violently and the machine stops. So I went through all the schematics and took it all apart, only to find that there is a 4" tapered nut under the tub that had corroded and snapped! Now the weird thing is that this particular part is NOT listed on the parts list and I cant find it anywhere!! The whirlpool people only gave me the answer that they don't make anything from this famously discontinued item. Please help!!
    Top Expert:
  • Whirlpool Master
  • 52,162 Answers
Whirlpool , simpson , westinghouse are all in the same manufacture house
you problem sounds like the tub suspension rod air dampers have failed
replace these rods and the tub is more stable
at the bottom end where the rods go through the mounts is a plastic cylinder that has a moving piston and spring inside ' the tip section of the plastic breaks free and then there is no air dampening effect
you will have to remove the top of the machine to get to the upper ends to replace the rods
cosy for 4 rods is around $90.00 AUD and can be got from the service agent spares
Posted on May 07, 2017
  • Whirlpool Master
  • 2,389 Answers
Try repairclinic.com or appliancepartspros.com
catriver
  • 878 Answers
SOURCE: whirlpool calypso washine machine
Skeet, verify you have 120vac to connector P-16 pins 2 and 4. If you don't have the power, check breaker, outlet, line filter, cord itself. If you do have that power, go to P-1 on the motor control board (left one), you should have 120vac across it's 2 terminals. If not it's probably the main board. Catriver..post back.
Posted on Oct 09, 2006
jsrock516
  • 5911 Answers
SOURCE: washer gets ld code
The ld fault is a long drain error. Check your drain pump reservoir and drain hoses for clogs. Removing the agitator in my opinion would be unnecessary. Unplug your machine and remove the back panel. There should be a drain pump reservoir at the bottom under the wash basin. They are notorious for collecting lint and hair and can obstruct the drain flow. You can also squeeze along the drain lines and feel for obstructions. To access the drain pump itself, its easier to remove the front panel. You will need to release the two metal hold down clips located under the front lip approx. two inches from either side. You need a putty knife to push in on the clips and lift on the top front at the same time. Once you have the top released, lift up and remove two screws holding the front panel. The front panel should pull away leaving an open access to the inside cabinet. The drain pump is located on the lower right-hand side of the wash tub at the very bottom of the unit. You can easily remove the two drain lines at the pump and check for obstructions there as well. Again, unplug the unit before servicing the pump. I hope this helps.
Posted on May 04, 2007
jsrock516
  • 5911 Answers
SOURCE: Calypso kenmore elite - problems trying to wash a load
This is usually a symptom of a bad motor control board which located under the console. I had the same problem. You can open the console by removing the three screws in the back and lifting from the rear first. The console will pop off. In addition, if you look along washer top front edge in the seam there is a retaining clip about 2 inches in from each side. Using a putty knife, push in on each clip while lifting and the top should pop up. There will be a tech sheet affixed to the front wall of the washer between the wash tub and case. This tech sheet will give you all the guidance necessary on how to perform tests to prove whether or not the motor controller is at fault, or if the pump is at fault. I believe you may have a motor controller problem, though. Another possibility is getting something caught in the drain pump reservoir. This could binding the pump. Let me know if any of this is helpful to you.
Posted on Aug 16, 2007
SOURCE: whirlpool calypso washer
Code LS=Lid Switch. I had the same problem and found that if you pressed down firmly on the lid when closing I would not get the LS code. An uneven load will sometimes cause enough vibration to the lid to stop the washer and display the LS code again. Just lift lid and press down firmly again and start. Eventually I will open it up and adjust the switch.
Posted on Apr 02, 2008
SOURCE: whirlpool calypso washing machine
Buy a new machine. We purchased ours from Sears 4 years ago, thank goodness we purchased the extended warranty, as Sears has been out numerous times to repair. In January 08, Sears replaced the pump only after they forced us to sign a waiver before they would even touch it, because my washing machine sits in a drain pan and they didn't install the drain pan. We signed the waiver (I need my washer) and the tech destroyed the drain pan and my my floor, basically she forced me to give her permission to do so. February 08 the extended warranty expired, June 08 the pump quit working again and Sears only warrantys part replacement for 90 days. BTW - the previous Whirlpool calypso model and Kenmore had a class action suit against them. Sounds like the newer models owners should do the same. Sears techs even told us to get rid of it. We bought a new one from Home Depot...
Posted on Jun 19, 2008
How do you remove the agitator and tub on a whirlpool Calypso washer?
THE CALYPSO HAS A TAB AT BOTTOM THAT NEEDS TO BE PRYED UP WITH A SCREW DRIVER THEN U CAN REMOVE THE SCREW WHICH HOLD IT IN
May 29, 2015 | Whirlpool Washing Machines
Where do you locate the model number on a whirlpool calypso?
The model number on Whirlpool manufactured top loaders is usually printed on a nameplate along the wash tub rim under the lid.
May 26, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Our Whirlpool Calypso model #GVW9959KL washing machine has started leaving light colored marks (kind of look like lint, but won't brush off like lint might) on dark clothes. Do you know of a way to...
sounds like you might have mold inbtween the tubs and its starting to wash loose and get on your clothes. try a washer cleaner like washer magic and see if that helps.
Feb 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer shaking and vibrating how do we get to springs and pads
To eliminate the vibration and the movement of your washer you need to align the four legs of your washer using level tools. Just put the level on the top of the four sides (front side, left side, right side and backside and then make necessary adjustment if needed on the 4 leg of the washer.
Feb 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Shaking uncontrollably during spin
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Washer: No water fill intermittent
Check the hose from the tub to the pressure switch, make sure its clear and the reservoir on the tub is clean.
Oct 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
at this point i hate to do this but if yo want a free replacement you have to contact whirlpool. this was involved in a class action lawsuit and they are making the repairs for free. otherwise replacing the pump is simple and you can get them off ebay for really cheep. :)
Jun 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
5,400 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
