I have a lexmark x1160 and it wont take in the paper properly, it takes it in at one side but then gets stuck, it has been like this for weeks now, i cant see in it what the problem is
    Genius:
  • 1,124 Answers
Tray loading problem could be caused by jam paper inside or bad tray device. Clean and see what happen
Posted on Sep 24, 2008
Necesito los drivers para la instalacion de la impresora
Click here You can download it from above link. Let me know if you need further assistance. Thanks for using FixYa.
Dec 06, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
Paper goes in slanted and wont print
Take the paper out off the printer and make sure there is no debris inside of the area where the paper normal loads from. If there is something stuck, you would have to shake the printer a bit to maybe get it loose to get the debris to come out.
Keep in mind sometimes kids put things in there and it gets in the way of the paper path. Also make sure there is no paper stuck in the paper path at all as this can cause the paper to go in slanted.
Aug 16, 2009 | Lexmark X2500 All-In-One Printer
When i try to print on my lexmark x3650 it wont take in the paper and then it tells me that its out of paper when the paper is in it.
hi
there is a small spoke like thing on the paper loading area check to see if this is stuck or brocken or the connection to the sensor there is brocken
cheers
pls rate if this was any help
Jul 13, 2009 | Lexmark X3650 Printer
Lexmark X8350 "communication not available"
I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
Jun 02, 2009 | Lexmark X8350 All-In-One InkJet Printer
Lexmark paper stuck
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck....
Jul 01, 2008 | Lexmark X2470 All-In-One InkJet Printer
Lexmark x83
Sounds like there is something like a part of a sticky address label, or a piece of other paper stuck inside.
Take a heavy piece of card stock and feed it through the paper path. Chances are, when you get the card stock all the way through, it will push out the offending object that is hung in the paper path.
May 19, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X5150 paper feed problem
the rollers may be dirty or there is a small piece of paper stuck down in one of the tracks or channels..
Mar 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Paper jam
Feb 28, 2008 | IBM Lexmark Z715 InkJet Printer
Paper Jam
If it truly stops halfway then it must be obstructed by seomthing. If it only gets a short way past the pick up roller then it may be something else. A little trick for removing obstructions is to fold your paper in half or even a quarter so it is much thicker and stronger and try to feed that through. This can push through any obstructions (assuming they aren't too big). If it still gets stuck see if you can manually turn the main gear found to the side of the carriage and try to push the paper through that way (hence pushing through your obstruction). If your paper feeds through fine doing this then you may have another issue.
Good Luck.
Please rate my advice, good or bad.
Feb 03, 2008 | Lexmark All-In-One Printer
Computers & Internet Logo
David Payne
David Payne
