Question about Ovens
Removal of hot plate hob
We are trying to replace a broken switch on my zanussi ZCE5200 thermaflow fan oven but we cannot lift the hot plate hob to get to the switch can you help please?
Mrs Clarke
    President:
  • 1,462 Answers
Usually you have to take the side panels off and hobtop is secured by screws to frame
Posted on Sep 25, 2008
Zanussi hob. Hot warning "H" remaining on permanently for one plate. Tried issolating power and back on- no joy.
It's a bad temp sensor on the surface element. You'll need to replace the whole element. If you have a glass cooktop, it's best to have a qualified repairman change it out for you.
Nov 25, 2014 | Ovens
Hi ive purchased a zanussi gas hob & electric grill and oven my installer wanted to knw what amp and wire to use to connect the oven nothing is stated in the manual model no ZOF35511XK
The necessary data for your installer is on
the rating plate. The rating plate is on the back side on oven and on the bottom side on hob. Never remove
the rating plate from the appliance cavity.
Make sure that the electrical information on
the rating plate agrees with the power
supply. If not, contact an electrician
All electrical connections should be made by
a qualified electrician.
The appliance must be earthed.
Dado
Sep 10, 2014 | Zanussi Ovens
Trying to change element on westinghouse PAK806 stove with ceramic cooktop. cant figure how to lift hob.
Hi I have a Westinghouse PAK806. The oven works fine, heat and fan, but none of the plates will turn on.
Any ideas?
Jul 13, 2011 | Ovens
Rented apartment and zanussi ceramic hot is displaying letter L on the hob plate control. There are no manuals around but unit looks new.
The "L" indicates that the child safety lock is on.
You haven't stated which exact model you have, but on most Zanussi's you turn the hob on and then press and hold the + and - buttons together until the display changes from "L" to "0".
Note that on some models you must do this every time you turn the hob on, on some others the lock can be disabled.
Jun 16, 2011 | Ovens
Hi We have a zanussi ZCE 7550 double oven cooker. The bottom oven broke (with a flash and bang), so we replaced the element at the back as it was burnt out. The top grill and hob are still...
Hello starsevern!! Did you get your cooker fixed, what was the problem?
I have a Zanussi ZCE7550, but apart from that I'm in exactly the same predicament as you in the post you made on Sep 18, 2010...
Can anyone help with a suggestion please???
Sep 18, 2010 | Zanussi ZDQ495 Electric Double Oven
Zaunssi ZBF360X built in Oven Not Heating
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
I have a zanussi buit under double oven the main oven all the lights come on but no heat. it worked yesterday well top oven works and so does gas hob
If it is an electric oven and fan assisted, and the fan is working o/k, then you need to fit a new oven element, located behind plate at rear of oven.
Please rate my solution.
Thanks.
Nov 12, 2009 | Ovens
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Ovens Logo
203 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
