Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Dishwasher just quit one day, controls or lights do not work, I have power so that is not the issue,
  • mike Oct 30, 2011
    sorry I do not see the reply, I would like to open up and look into door control to see if a problem
    New Friend:
  • 63 Answers
The first place I would suggest that you look, is to make sure your door is closing all the way. Make sure nothing has gotten stuck down at the bottom of the door and no silverware is stopping it from closing. You dishwasher has a door open/ajar switch that in a part of the door lock. If it is even just a little bit open, it will stop power to the timer and will not come on at all. Unless you are very comfortable with electricity, I would suggest you do not open the cabinet up as you are mixing two very dangerous items. Electricity and water.... you could receive a very bad shock or even death if you don't get it right the first time. If you are ok with the possibility, I can give you additional info.
Posted on Oct 30, 2011
  • mike Oct 30, 2011
    reviewed door issue, no obstructions, as empty, door latch clicks when closed. I checked power and has power to the door where the wires goes within middle of door leading the the control panel, is there a reset button or a control panel issue, willing to open and explore
  • Happy N camping Oct 31, 2011
    The only place that you might have a reset button would be on the bottom of the pump motor. Unless you have a lot of experience with electrical products, would suggest having it checked by a repair man. If you do have the knowledge, then there is a electrical diagram on the lower door plate, or rolled up and in the frame work.
SOURCE:
Haier dishwasher keeps tripping electricity for the plugs for last few days. Is it a power source issue or a dishwasher problem
You can turn off the breaker that is supplying power to the dishwasher, and pay close attention to whatever else no longer has Power such as light fixtures, plugs, etc. it is quite possible that the circuit may be overloaded (too many devices on that breaker) your problem may only occur when all of the devices are being used at the same time.
Dec 07, 2013 | Dishwashers
Bosch Classix SGS43C12 dishwasher programs not working & dispenser drawer not opening
The control board on this model is know to have issues with dry solder joints, If you are handy with a soldering iron you can fix it quite easily.
Mar 04, 2012 | Bosch 24 in. SGS43C12 Classixx...
F&P dishwasher (DD603i) has no power to top drawer
No power to the top drawer needs to be verified.
Are you saying the lights are blank and when you press the start buttion nothing happens?
One reason the controller can shut the power is that the heater overload protection thermal resistor has opened. Unfortunately the only way to fix this is to replace the entire heater plate at the bottom of the drawer.
To confirm if the controller is operational or not, press Keylock and Start/ Pause button together for 5 sec (press Keylock first) and see if the Lights light up. If nothing happens then either the power has shutoff as mentioned above or controller is faulty.
Depending on your familiarity with such equipment you could try to replace and fix. I am not quite sure what the new model you mention is. I believe all DD603 models have power to the 2 drawers coming from the base board.
Feb 06, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher doesn't turn on, nothing happens when I push on the start button, it doesn't light up, was working the day before
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch Replace if defective.
3. Timer/control board Replace if defective (note: uncommon problem).
4. Selector switch Replace if defective (note: uncommon problem).
Sep 21, 2009 | Dishwashers
Dishwasher stopped and will not start
Try jigling the ribbon cable that is connected to the control panel. These ribbon cables sometimes fail. Also check the fuse on the control board to see if it is blown.
Jan 02, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Viking dishwasher quit working
Possible bad door switch, thermostat or timer issue, call for service, make sure the tech. knows how to fix Asko dishwashers as that is what is in on the inside. Be sure that you are getting power to the unit.
Jul 16, 2008 | Viking 24 in. Professional Series VUD040...
Whirlpool dishwasher
fuse on control board.
Jan 11, 2008 | Dishwashers
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
91 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
