Question about HP PSC 2175 All-In-One InkJet Printer
Page Counter? Where can I get the page count on the HP 2175 printer. I want to know how many pages I have run through it.
  • 234 Answers
If the printer was reset recently then you will not et the entire or exact page count till day, but you can still run a Print self test report and check for the information:
To Run:
  1. On the front panel of the product, press Menu (or Setup) .
  2. Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK .
  3. Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK .
It will print a self test page and you will find the page count in thie page
Good Luck
Posted on Sep 24, 2008
I wish to know on how we can get the page count of our newly purchased Canon LBP2900. we already tried printing the test page, but no data of page count on it. please advise the best solution. thanks!
Hello, These home oriented host based printers does not have the ability for the user to check the page counter. Sorry. You can install additional software on your pc which can count the pages from now on, but will not show the information from the beginning.
Sep 23, 2011 | Canon LASER SHOT LBP-2900 Printer
Tip
How to get the page count on a Ricoh Aficio copier
On Ricoh's Aficio line of copiers, you can get the page count without having to print out a configuration page or status page. To see the page count of an Aficio copier, follow the steps below.
For models with touch screens:
With the copier turned on, press the User Tools/Counter button on the operation panel. (If User Tools and Counter are two separate buttons on the model you are using, press the Counter button, and the page count will be displayed -- that's all there is to it.) When the User Tools menu appears on the screen, press the Counter button on-screen (typically located in the lower left or lower right corner).
The copier's page count will be displayed on the screen. For copiers with additional functions (such as printing) the page count will also be broken down by function. Color copiers will display a color page count and a black and white page count, but not a total count.
You can print out a hard copy of the page count if you want it for your records, or to fax somewhere. To print the counter, press the Print button on the screen, then press the Start button (on the right side of the operation panel).
For models without a touch screen:
With the copier turned on, press the User Tools/Counter button on the operation panel (typically located just to the left or right of the display screen). The User Tools options will appear. If Counter is the highlighted option, press the OK button to select it; otherwise, use the arrow buttons to select Counter, then press OK.
The counter will be displayed on screen, but you can print it out by pressing the selection button below where Print is displayed, then pressing Start.
on Jun 13, 2011 | Office Equipment & Supplies
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
LaserJet 4250n Printer: When you change out the ink cartridge, is there a ...
When you change the Toner Cartridge out, you do not have to reset the page counter, this is done when a maintenance kit is installed, Though if you would like to track how many pages, you could get the current page count from the configuration page, which is accessed by going to the Menu-----
May 18, 2010 | HP LaserJet 4250n Printer
How do you run a page count report? HP Laser Jet 1320N
Configuration page
The configuration page lists current settings and contains a status log report.
To print the configuration page from the printer, press GO for 5 seconds, until the yellow light comes on, when the printer is in the ready state.
NOTE Make sure that you hold the GO button for less than 10 seconds.
Apr 19, 2010 | HP LaserJet 1320n Printer
Is there a counter for pages printed on my 1320n
No, the page count is not on the test page. You need the configuration page. Press the GO button and hold for 5 seconds. The yellow light will come on and you can release.
Apr 05, 2010 | HP LaserJet 1320n Printer
Reset maint counter
1. Select Reset Maintenance Count Configuration menu.
Page 3-17 of IBM's service guide
Mar 25, 2010 | IBM Infoprint 1352 Laser Printer
I cannot find the website again that explains how to clean the hp psc 2175 all-in-one printer.
http://h10032.www1.hp.com/ctg/Manual/bpu73527.pdf
see maintenance page 7 and theirs several other pages as well.
Sep 20, 2009 | HP PSC 2175 All-In-One InkJet Printer
How to determine printer page count
that model of HP printer did not have a page counter that could be printed
Apr 21, 2009 | HP LaserJet 1020 Printer
HP PSC 2175 All-In-One InkJet Printer Logo
143 people viewed this question
Seeker5211
Seeker5211
