Question about Toshiba Computers & Internet
Wireless connectivity What do I need to make this old computer wireless compatible for my daughter
  • ksmith1968 Sep 25, 2008
    Thank you very much Im completly computer illiterate and was going to scrap this old pc which someone gave me. It took me 2hrs to find an appropriate charger for it. I wish I had just asked you! Thank you my daughter will be delighted.
  • Toshiba Master
  • 32,281 Answers
You need a PCMCIA wireless card in the laptop to connect to your ACCESS POINT to communicate with the Internet and your "home" networked computers.
Posted on Sep 24, 2008
Can i connect new pc to old connection
You simply need to disconnect old computer from the network and connect the new one.
Are you trying to connect wired computer or wireless?
If you are trying to connect a wired computer then you don't need to do anything.
Just take out the Ethernet cable from the old computer and connect it to the new computer.
If you are connecting a wireless computer to the network then make sure that you have all the settings of your wireless router.
If your wireless network is secured then you should know the correct network key.
What is the operating system on your computer?
I will suggest you a website " The Router Setup " which may help you connect your new computer to the old wireless network.
May 17, 2012 | D-Link AirPlus DI-524 Wireless Router
Hi, I'm a guest in a cottage with a router. Although I typed in the password I can't connect to the internet wireless. I've had the problem also at home with an older router. But on my way here I had...
Depending on your computer there can be a couple of issues. Of course if the password is typed incorrectly you would not be able to connect, but depending on the type of encryption being used, the computer may have a hard time connecting either way. First if the wireless routers are using WEP for the encryption it is more likely that even when you type the password in correctly it still will not connect. WEP is very old and buggy and tends not to work correctly. If the computer you have is older (Windows XP) and the wireless routers are using WPA2-PSK for the wireless encryption then it may be a compatibility issue on the computer. Windows XP was not originally compatible with WPA2. In Service Pack 3 it was updated to support it but still some of the older wireless cards do not fully work with WPA2-PSK.
Mar 05, 2011 | D-Link DIR-615 Wireless Router
Every time i secure the router the wpa/wep isnt compatible with my daughters laptop.....not too sure what do
Does your daughter have a very old laptop? Some older wireless cards do not support wpa/wep. You can still get her a USB wireless adapter and use that to connect to the router.
Mar 01, 2011 | Belkin F5D7234-4 Router
I have an HP Pavilion dv4. The wireless connection disables when the computer is bumped or moved. Also, the computer will freeze up and shut down when it is bumped. I read a forum that said to go into...
Sounds that the wireless adapter daughter board is either loose or failing. First, we need to make sure it is making good contact with the laptop's motherboard. In order to do this, we have to do the following:
1. Turn off the laptop & remove the battery.
2. Look at the compartments in the bottom of the laptop. You should be able to see 2 or 3 areas with small rectangular plates covering them. These plates usually have one or 2 screws holding them in place.
3. Check which one of those plates is the one which covers the wireless adapter daughter board. When you find it unscrew its screws & remove it.
4. Below the plate, there will be a small daughter board screwed to the laptop's motherboard, with 2 thin wires attached to it (usually one black wire & the other is a white wire). Gently, remove both wires using a small flat screw driver to pull them out gently. Don't forget to note down which wire connects to which connection point.
5. Unscrew the wireless adapter daughter board & remove it from its slot.
6. Clean both the slot & the daughter board's terminal connectors using a dry electric contact cleaner. You can purchase it at an electronics store.
7. Leave the slot & the daughter board for a while to dry.
8. Re-place the daughter board back in the slot & screw it to the motherboard.
9. Reconnect the 2 wires.
10. Screw back the covering plate.
11. Put back the battery & turn on the laptop. Check if the problem was fixed.
If this did not fix the problem, you will need to repeat the steps to remove the wireless adapter daughter board & replace it with a new one.
Oct 26, 2010 | HP Computers & Internet
II have been trying to connect wirelessly my new HP lap top to an old series 600 but the computer can't connect even after entering the key. It works ok on cable.can any one help
1. your issue is due to a a wireless laptop is not compatible with the old router or
you may need a firmware upgrade.
2. the cold compute may be able to connect via a cord (Ethernet) but not wirelessly due to an outdated driver for the network card ( the card will need updated drivers also) if it is a wireless b card then the ability to us a WAP key will not be possible
because your card was designed to use WEP key.
3. a new wireless G card installed to the old PC will allow connectivity if the wireless card is backwards compatible.
4. most all PC's can connect via a Ethernet cord they are all designed that way and have not changed for the 20 or 30 years they have been in use.
I hope this helps. Have a great day!
Oct 05, 2010 | Zyxel P660HW-D1 Router
My daughter has an hp pavillion desktop - windows xp - year 2002 - I have internet via cable company - I was trying to set her up to use wireless internet - i find no wireless capability other than...
You would need to purchase a wireless adaptor to add to your daughter's pc. Once installed alone with the drivers/software, you should have no problem getting her connected wireless.
Good Luck
C2Solutions
Jan 21, 2010 | Computers & Internet
My daughter has an old Dell Inspiron and it works great with a Belkon router but when they got the netgear wireless router she gets a blue screen. What do I do?
Need to check for driver compatibility for the Netgear router . Contact Netgear for backwards compatibility or purchase a router that will be compatible with your PC.
Aug 04, 2009 | Dell Inspiron 1000 Notebook
Ok, my previous question was answered about hp pavilion zx5000
You need to check whether it has compatibility with that router or not?
if yes, you need to make sure the operating system would meet all requirements...
Note - I am assuming that you have an inbuilt modem for wireless connectivity.
Check with vendor or router company if have any issues before you purchase.
Thanks for using "Fixya".
Jun 03, 2009 | HP Pavilion zx5000 Notebook
My netgear wireless router
Is it th win 2000 computer that you want to get a wireless connection? Do you have a wireless adapter on that computer that you want to go wireless?
Jun 29, 2008 | NetGear WGR614 Router
Emachine model t3302 ethernet card
This is how the wireless world works. You buy a wireless router with a four port switch. Your DSL or cable connects to that. A cable called a Rj45 connects the DSL or cable to the back of the wireless router. You also buy a wireless network card for your PC. After running the software for the router & the wireless nic card including setting up a home network through windows your daughter will be able to connect that computer to your network from any room in the house. Below is a link to a wireless router:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005578
You can connect up to four computers to the wirless router. A computer that does not connect to the router by a Rj45 must use a wireless network card. Linksys WMP54G Wireless-G PCI Adapter Retail: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=252286
As you will see there is a big differance between a NIC card & a wireless card.
Jan 01, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
