Question about Kirby G6 Bagged Upright Vacuum
Fan and bearing replacement on a Kirby G6
I was that told by the new owner of my vac repair store that I needed my fan replaced on my Kirby and that if the fan was replaced, the bearings needed to be done as well. I had the fan and bearings replaced last year(I **** up a lot of rocks), as well as a tune up ect.., when the fan broke. I put about $200 into the vac last year and was hoping to replace the fan myself. How can I tell if the bearings need to be replaced? mean I need to replace hte armiture? Finally, if I do need to replace the bearings, which parts do I absolutley need? Any repair tips would be great. . I am trying to figure out what to order. I would love any help I can get.
  • 37 Answers
If you run your vac to long after the fan is broke it will cause excessive vibration and the bearings can go out. in almost all cases i replace the fan only. most of the time if you have a bad bearing the vac will make a grinding noise. you can also tell a bad bearing by grabbing the belt pulley on the end of the fan and pull up and down if it moves alot then your bearing is also bad. you can get the bearings separate witout ordering the armature assy. when talking of replacing any of these parts besides the fan i would advise you to take your vac to your local repairman. working on motor parts of a kirby can get pretty involved. to replace the fan first take the housing off where your belt and brushroll are. you should then see 5 screws on the front of your kirby. remove all 5 screws. then remove the handle. at the very bottom of your handle you will see a piece that allows you to move the handle, on the back side of this you need to push in with your thumb and the handle should pull off. then you should see a plastic piece directly below that snaps into the top housing. remove the 2 screws from this. one where the cord boot is and one above your power drive neutral/drive lever. then under this plastic piece is 2 more screws on your top housing. when these are out your housing should pull off. if not then remove the bottom plastic housing of your outer bag. then go back and look at the front again and you will find since removing the top housing you have exposed 2 more screws in the front fan cover housing that also need to come out. after this pry this housing off and you should be looking directly at the fan. grab fan with pliers in one hand and with the other hand apply pliers to the silver belt pulley and turn this piece clockwise. it should unscrew and then you can pull your bad fan off and attach the new one. i hope this helps and remember its not as hard as i probably made it sound. good luck!!!!
Posted on Sep 25, 2008
My g7 will not pick up anything
Without more information, my first guess is a worn or broken fan. You can take it to a shop and have it replaced, or buy one from a Kirby store and replace it yourself. There are also on-line stores where you can purchase impellers.
Here are instructions for replacing the fan:
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302
Here are video clips showing how to do it yourself.
http://www.youtube.com/watch?v=WJvw4NujOpU
http://www.youtube.com/watch?v=wS9nrQr_Kvc&feature=related
Feb 12, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Wont **** properly. is just moving dirt around. i have a G6 i unclogged it changed the bag. dont know what else to do.
With a Kirby that's around 10 years old, there's a good possibilty the fan is worn or broken. You can purchase one online (http://www.elikirbyclub.com/category_93/Kirby-GSix-Fan.htm for $17.55 plus shipping and handling) or at a Kirby store.
Instructions for replacing the impeller can be found at the following site.
http://www.ehow.com/how_5534689_replace-fan-kirby-vacuum-cleaner.html
Jan 03, 2011 | Kirby G6 Bagged Upright Vacuum
I need to fit a new fan to my kirby g4 but
I wouldn't recommend doing this yourself. If you had to ask how, that's proof you shouldn't bite this one off. Take it to a vac shop. This is a very involved repair. A vacuum professional can easily do it, but it would cause you great stress and heart acke
Apr 29, 2010 | Kirby G4 Bagged Upright Vacuum
REMOVING HOSE END
I had to replace the hose end on my Kirby, the motor end. I have the Diamond edition. Just take a hair dryer and get the end of the hose warm, and then us a screw driver. Works like a charm. It stays warm long enough to put the new end on.
May 29, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby G6 without suction
you probably have a clog in the feed tube going from vacuum head to the bag try removing bag and check for clog there hope this helps
Aug 20, 2008 | Kirby G6 Bagged Upright Vacuum
Owners manual for kirby g6
The Kirby G6 Vacuum Manual is available for free on this site: http://ubermanuals.com/product/kirby-g6-8499 .
May 13, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Vacuum Fan
The pullet is what holds it in place, if it has come loose, just tighten it. But if that doesn't help, then replace the fan.
Mar 12, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
374 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
