Question about Intel Motherboard
I cant use the four sides of sockets of rams on my gigabyet p31 if any1 know plz ty the pc keeps botherin me when i try to put more than 2 giga rams wtf
  • 781 Answers
Unless you are using a 64 bit operating system you can only use up to 3.5GB ram
Posted on Sep 25, 2008
Windows 7 shutdown problem
take out the battery on the motherboard and unplag the pc main power cord and press the power on button for 5 seconds then plug in the mains and the battery start up the pc and see if it will shut down.
Dec 30, 2013 | MSI P31 Neo-F Core 2 Quad Socket 775...
Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
You may have tried to put too much memory (RAM) onto it.
That models maximum spec is:
Memory upgrade information:
  • Four DDR3 DIMM (240-pin) sockets
  • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
  • Supports Dual channel memory architecture
  • Supported speeds
    • PC3-10600 @ 1333 MHz*
    • PC3-8500 @ 1066 MHz
      *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
  • Non-ECC memory only, unbuffered
  • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
  • Supports up to 4 GB on 32-bit PCs
You can find the specs and troubleshooting help files here
Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
Motherboards
the abit gd8 is since it has pci-express for video card also faster frontbus speed and the cpu is intel . The ga-7vm400am is a old board and for AMD XP cpu. here is 2 link 1 for abit and other for giga
ABit
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?fMTYPE=LGA775&pMODEL_NAME=GD8
Giga
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1747
Sep 08, 2009 | Intel Motherboard
Whn i setup whndows xp sp3 the sound dont work
Follow the instructions here to update your device drivers.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 27, 2009 | Gigabyte GA-P31-S3G socket LGA775...
Cant get any power to run through my laptop
Tyr this:
Gently remove and clean (with a pencil eraser) and reinstall your memory, then try again.
For you non-techies, it is very easy to hose a perfectly good laptop by NOT fully releasing the side-latches (some metal, some plastic) BEFORE gently lifting the RAM up 1/4", away from the pin/contact seating area, and OUT of the sockets. Actually, if you do it right and do not physically touch the face, sides or corners of the RAM when you use your Left and Right thumbnails to 'tease' the latches away from the sides of the RAM, it will POP out all by itself. smile1.gif
Now... putting new RAM in is REALLY easy and does not require any force or pressure at all. Look at the socket and the RAM and orient your RAM so the slot in it (the RAM) and the raised portion of plastic in the contact seating area line up. If it is OBVIOUSLY not, flip the RAM over and check again. If it still will not, or can not line up... it is the wrong type RAM for your machine. Take it back. Do not try to 'make it fit' ;-)
Once you have RAM oriented so it WILL slot in, take the RAM between your index fingers and thumbs so the contacts are facing AWAY from you and hold firmly by putting the tips of your fingers into the holes on the sides of the RAM, ease the RAM into the socket and seating area, wiggle a bit side to side and seat in snugly, then maintaining the hold with your 2 Thumbs, tease the latches away from the socket edges with your fingernails (under the edges of the new RAM) so they both clear the sides of that RAM, then gently press down a bit further with your thumbs until the RAM face is below the latches and finally release the latches making sure BOTH are now above the RAM face. Done.
Don't FORCE... EVER ;-)
Hope this helps!
Feb 18, 2009 | Toshiba Satellite A105 Notebook
Intel Motherboard Logo
26 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
