Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Water filter initiation failed
After changing the water filter in my Saeco Primea Ring Cappuccino I got the message "filter initiation failed, contact assistance". What do I do now???
  • jillsundsted Sep 26, 2008
    Yes I followed those steps but the machine couldn't initialise the filter. That's when I got the message "initialation failed". Now I can't get that message to go away,,,
    THANK YOU EVER SO MUCH!!!! I deactivated the filter and now the machine works again. I've really missed my coffee...
  • 515 Answers
Did you this steps?
Fill the tank with fresh water.
Let the filter soak for 30 minutes.
After 30 minutes discard the water in the tank and refill with fresh water.
Place a container under the spout.
Press the cup button in the middle.(Filter on, yes)
Press the cup button again.(press ok, initialisation)
The machine initialises the filter.
Press the cup button again.(done initialisation)
Then press MENU repeatly. When the "exit" message is displayed, press the cup button. In this way, the machine ends the start-up phase.
Best regards
/Mirran
Posted on Sep 25, 2008
  • Mirko Blas
    Mirko Blas Sep 26, 2008
    Can you get in to the menu?
    If you can then go in and deactivate the filter.
    /Mirran
Hi, I have the Saeco Primea Cappucino Touch Plus , and it syddenly gives the error code 5 - Call assistance. I have just changed the primea Water Filter - same way as always ! What can I do ?
Need to prime the machine. The new water filter is causing the air lock in the system.Remove the filter and startup the machine it should prime by itself, when it's ready,fit the filter back and press hot water until the water flows steady. Hope it helps.
Sep 05, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
We have cracked our plastic water tank reservoir on our Saeco Cappucino/Espresso Maker and need to replace it.
You can special order the water tank by visiting our website http://cerinicoffee.com/Saeco_replacement_parts.asp
If the item is not listed please contact us.
Cerini Coffee Services
Authorized Saeco Service Center
www.CeriniCoffee.com
Nov 10, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Walter initiation failed
Did you this steps?
Best regards
/Mirran
Sep 24, 2008 | Saeco Vienna Espresso Machine
Saeco primea Ring
What i know there will not be any dvd or cd, it´s only on paper:-(
/Mirran
Sep 03, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino brewing very slowly
Try to descale the machine.
Try to adjust the grinder little.
/Mirran
Aug 21, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker fill water tank
The Primea do not have a float, it have a magnet and inside the machine there are a printed circuit card, this send a signal to the powerboard.
Jun 20, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
New Primea Touch Plus Machine
in the water container they is a float .the float is probably stuck tap gently the container it should work cheers
Dec 25, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
Nov 10, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
162 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
